Wheel alignment question
Postby FST4RD » Fri May 10, 2013 8:36 pm
Hi all,
My Legacy went in today for a wheel alignment today. I have the print out and upon studying it I have a few questions.
I am assuming where it says "Before" it means the original measurements, "Actual" is what it is now and "Specified Range" is the range that the "Actual" figures should sit between?
Also for the front wheels it has a list of things like Camber, Caster etc... one of them is SAI (or SAJ, dodgy dot-matrix printer) what is this? It says the range is 13"35' - 15"05' but one wheel is 15"20' and the other 15"29'. Is this going to matter?
Also does anyone know if a '95 Legacy SW has rear toe adjustment? The right rear wheel is within range, but the left rear shows that it was 2.2mm and now 2.3mm (the range is -1.5mm to 1.5mm).
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Lloyd » Fri May 10, 2013 8:45 pm
Have a quick read: http://www.anewtoronto.com/wheel%20alignment.html
And no it isn't going to matter, and not all the measurement they give you are adjustable anyway. Changing some will slightly change other, but if it's that close to spec then don't worry about it.
Postby Grrrrrrr! » Fri May 10, 2013 8:46 pm
Pretty sure anything that doesn't have a live axle has at least toe adjustment.
Grrrrrrr!
Postby Lloyd » Fri May 10, 2013 8:54 pm
Sorry, missed the rear toe bit. If they're adjustable then I'd be asking them to set it properly
Postby FST4RD » Fri May 10, 2013 9:00 pm
Lloyd wrote:Sorry, missed the rear toe bit. If they're adjustable then I'd be asking them to set it properly
Yeah I'll give them a ring tomorrow if they're open.
I personally didn't take the car down to the place for the alignment... but I'll definitely find out.
FST4RD
Postby touge_ae101 » Fri May 10, 2013 9:00 pm
Sometimes for a road car and normal alignment place they will set it outside the normal limits to make it drive straight etc on our cambered roads..
touge_ae101
Postby FST4RD » Fri May 10, 2013 9:01 pm
touge_ae101 wrote:Sometimes for a road car and normal alignment place they will set it outside the normal limits to make it drive straight etc on our cambered roads..
Perhaps the camber... but for 1 wheel to be out of toe?
FST4RD
Postby wde_bdy » Fri May 10, 2013 9:25 pm
Half of the supposed professionals can't even work out what is and isn't adjustable on most cars. :?
Callum
wde_bdy
Postby DRFTIN » Sat May 11, 2013 1:11 pm
is the car lowered? they might have run out of adjustment?
DRFTIN
Postby FST4RD » Sat May 11, 2013 4:49 pm
Rang them this morning and found out why
Apparently with Christchurch roads you have to run a pinch more camber on the left, and to stop the tyres wearing on the inside they compensate by adding a bit more toe
Sounds reasonable to me, most Christchurch roads are quite off cambered
FST4RD
Users browsing this forum: Google [Bot] and 48 guests
