Diff servicing/rebuild Auckland
Postby theDiff » Sat Dec 28, 2013 10:52 pm
So I think my Runx Z diff needs some love - still getting a bad wurrrrring noise on deceleration in 4th/5th/6th gear. From what I have researched it could be the pinion bearing or perhaps another bearing in the diff. I know it's not the tranny or clutch or pulleys because they have all be checked/replaced. So it has to be the diff. Anyone know any good Auckland specialists?
theDiff
Re: Diff servicing/rebuild Auckland
Postby steroidcontaskie » Sun Dec 29, 2013 12:17 am
Steelie gears in otahuhu is good and well priced.
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby matt dunn » Sun Dec 29, 2013 10:02 pm
What sort of clutch plate does it run?
Postby AE25 » Tue Jan 14, 2014 9:10 pm
is this the same bearing issue that 5speed corolla fielder wagons have?
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby theDiff » Wed Jan 15, 2014 5:03 pm
Nope - it's not a bearing issue. All bearings have been replaced (not cheap) and the noise remained. But the chaps at Gearbox Factory figured it out!
I got the car with a heavy duty clutch that had a solid brass center (previous owner installed it for whatever reason) and unknown to him, when installing a clutch of this type in certain vehicles, there can be an increase in transferred harmonic noises from the engine to the gearbox. This may also cause gearbox rattle - particularly on decel.
These transmitted noises in no way affect the performance of the clutch or the vehicle, and is widely accepted in the performance industry, where engine and/or clutch modifications have been carried out. So there you go!
I'm getting a heavy duty center with duel springs put into the OEM clutch which will make it much quieter.
theDiff
Postby matt dunn » Wed Jan 15, 2014 10:24 pm
I have struck that too with solid centre clutches, that's why I asked.
Glad to know it was not diff issue.
Postby theDiff » Thu Jan 16, 2014 9:40 am
What solution did you come up with that worked - if anything?
theDiff
Postby 1I1 » Thu Jan 16, 2014 9:52 am
It's come up on here a couple of times and OEM clutch has removed the noise.
TRD Clicky >>Here
1I1
Postby theDiff » Thu Jan 16, 2014 2:04 pm
I put an OEM in and it did nothing so the gear box factory lads put a heavy duty plate in and they believe it's worked. Horses for courses I guess.
theDiff
