pyro_sniper2002 wrote::roll:
Oh well as long as well all know they do nothing for your audio.
I've never had any problems with dimming lights either, as dimming lights is simply caused by voltage drop. So get a good enough battery, no voltage drop, hence no dimming lightsdeaf_rattle wrote: but i bought the cap with trying to fix the dimming lights problem, and im pretty sure thats how they are marketed.
Blackrazor wrote:I've never had any problems with dimming lights either, as dimming lights is simply caused by voltage drop. So get a good enough battery, no voltage drop, hence no dimming lightsdeaf_rattle wrote: but i bought the cap with trying to fix the dimming lights problem, and im pretty sure thats how they are marketed.
Blackrazor wrote:CCA is like peak watts - largely meaningless for everyday use.
What IS important is how the battery holds up under load and whether the voltage drops as it provides power. Hence why medium output deep cycles (Optima, etc) work better than supposedly higher output starters
Or to explain another way - you want a battery that can do steady, moderate current over a long time, rather than one with a massive burst of current for a few seconds and then goes 'phut'
