currently i have:
JVC head deck KD-S785
- 45x4
6.5" Boschmann 3 ways
- Peak Output Power: 200 Watts
- Continuous Output Power: 140 Watts
- Normal Output Power: 70 rms
- Frequency Response: 50 Hz - 20 Khz
- Sound Pressure Level: 92 db 1W/1m
- Nominal Impedance: 4 Ohms
6.25" 3 way rears (not installed yet
- 60W RMS
- WOOFER: 160MM
- INPEDANCE: 4 OHMS
- SEMSITIVITY: 90DB/W (1m)
front and rear speakers are just running off the head deck, i might look at getting another amp for them at some point
I know its not the flashest set up, but im not the biggest music lover around nor the richest, just adding to my car
I like the look of this sub
http://www.parallelimported.co.nz/view.php?item=5735
and am thinking about b uying my mates lanzar vibe 418 amp.
which is rated at 4x100wrms (2x200wrms bridged)
what Im wondering is if that amp and sub are compatible?
if i put one channel of 200w into each voice coil? (is that how it works?)
thanks (im out of my depth when it comes to car audio
![Razz :P](./images/smilies/icon_razz.gif)
Logan
