AE101 Levin set-up help please :)
Postby 92GTApex » Tue Dec 13, 2005 11:25 am
Im thinking about getting a sub and amp for my Levin AE101
currently i have:
JVC head deck KD-S785
- 45x4
6.5" Boschmann 3 ways
- Peak Output Power: 200 Watts
- Continuous Output Power: 140 Watts
- Normal Output Power: 70 rms
- Frequency Response: 50 Hz - 20 Khz
- Sound Pressure Level: 92 db 1W/1m
- Nominal Impedance: 4 Ohms
6.25" 3 way rears (not installed yet
- 60W RMS
- WOOFER: 160MM
- INPEDANCE: 4 OHMS
- SEMSITIVITY: 90DB/W (1m)
front and rear speakers are just running off the head deck, i might look at getting another amp for them at some point
I know its not the flashest set up, but im not the biggest music lover around nor the richest, just adding to my car
I like the look of this sub
http://www.parallelimported.co.nz/view.php?item=5735
and am thinking about b uying my mates lanzar vibe 418 amp.
which is rated at 4x100wrms (2x200wrms bridged)
what Im wondering is if that amp and sub are compatible?
if i put one channel of 200w into each voice coil? (is that how it works?)
thanks (im out of my depth when it comes to car audio :P )
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Re: AE101 Levin set-up help please :)
Postby barryogen » Tue Dec 13, 2005 3:51 pm
92GTApex wrote:and am thinking about b uying my mates lanzar vibe 418 amp.
don't do it... or if you do, do it temporarioly.
barryogen
2ZZ Guru in training
Postby DeeCee » Tue Dec 13, 2005 3:57 pm
Barry - you're best to explain why you advise not to purchase the Lanzar instead of a blanket statement ;)
GT Four Adovansu
DeeCee
Postby 92GTApex » Tue Dec 13, 2005 4:26 pm
yes please...
like i said im a complete noob...
at the moment hes running 2 sony 12" the pentagonal ones 1200watt version i think and it sounds pretty good to me
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby 86_rolla » Tue Dec 13, 2005 5:00 pm
92GTApex wrote: it sounds pretty good to me
honestly get what YOU think sounds best because what i like u may think sounds like shit and vicsa versa. So and have a listen and decide.
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby 92GTApex » Tue Dec 13, 2005 10:35 pm
but its an amp not the sub which im getting.
and its set up completely different to how I want to run it.
So how can i get what sounds good to me?
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby GGnz » Wed Dec 14, 2005 10:46 pm
Dont go with the Lanzar. I had a Vibe258. First it blow my sub for some reason. So got a new sub and now the amp is not working properly. Better getting a decent brand.
GGnz
Postby 92GTApex » Wed Dec 14, 2005 11:07 pm
this is a low budget setup... total cost is $94.90 so far for head deck and front and rear speakers.
and im prolly going to get the amp 4 $100
So yeah, im not looking at spending thousands 4 the best components and install
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby Alex B » Wed Dec 14, 2005 11:54 pm
GGnz wrote:Dont go with the Lanzar. I had a Vibe258. First it blow my sub for some reason. So got a new sub and now the amp is not working properly. Better getting a decent brand.
Probly because you were cronicly underpowering it.
Postby GGnz » Fri Dec 16, 2005 2:18 pm
Yeah well. Sub is sold, amp is scrap and 15" DD sub and eAudio amp is for me next year :wink:
GGnz
Postby Alex B » Fri Dec 16, 2005 2:36 pm
My SQ setup with pwn your SPL setup sunny jim :P
