Stereo brackets
Stereo brackets
Postby DJ » Fri Apr 27, 2007 2:20 am
I want to put a headdeck /stereo in my car, but its missing the factory stereo brackets (things the hold the headdeck in), since factory ones are rare as hens teeth, would AW11/AE82 ones be the same?
Oh, and its a double-dim slot too and im only putting in a single slot deck, so where do people get those little plastic dim covers?
DJ
Postby AJz » Fri Apr 27, 2007 3:12 am
din, not dim
Ive never found the din slot blanks, heard people say jaycar or supercheap but im yet to find some.
I had vtax :(
AJz
Postby Boosted_162 » Fri Apr 27, 2007 3:33 am
Repco do actually stock them, at least the ones up here do. You might have to ask them to order it in for you.
Postby Andy » Fri Apr 27, 2007 8:53 am
Andy
Postby big_boy » Fri Apr 27, 2007 11:17 am
you can get blanks from installer survices AJ there about $10 just ask for phil there opposit rebal sport or about there on the other side of the one way
as for the stero brackets in question from what iv found there a basicaly 3 types for toyota up to 1993 ish theres straight mount starged top & bottom (both ways) most of them are the same mounting point with different holes to put the H.U in the right place for the dash so if you get some with the right mounting then just drill more holes/add washers to make it sit were you want
for sale EE90
big_boy
Postby flat_0ut » Fri Apr 27, 2007 10:53 pm
Maybe a dumb question but have you tried toyota?
flat_0ut
Postby snwtoy » Fri Apr 27, 2007 11:16 pm
Specialized car stereo shops also sell those strip-type brackets which you can bend to suit. Useful not only for car stereos.. :)
snwtoy
Postby Ae92typeX » Sat Apr 28, 2007 5:05 pm
through revvy may be an ok price...went for a set for the supra years ago, and were a bit of a rip. personally, If I have a car without them I just make out of alloy or steel. Make up a cardboard template, then mark drill and bend- not hard really.
Ae92typeX
