by big_boy » Fri Apr 27, 2007 11:17 am
you can get blanks from installer survices AJ there about $10 just ask for phil there opposit rebal sport or about there on the other side of the one way
as for the stero brackets in question from what iv found there a basicaly 3 types for toyota up to 1993 ish theres straight mount starged top & bottom (both ways) most of them are the same mounting point with different holes to put the H.U in the right place for the dash so if you get some with the right mounting then just drill more holes/add washers to make it sit were you want
for sale EE90
