alarm question
alarm question
Postby fx gt » Thu Apr 17, 2008 9:15 pm
putting a fusion alarm into my corolla
have one problem
i have a wire that goes to the door switches, so that when any 4 doors are opened the alarm goes of :lol:
but where do all the 4 door open/closed switches meet up?
fx gt
Postby soopachargen » Thu Apr 17, 2008 11:15 pm
look for a red with white trace in your drivers kick panel, this should do all your doors, if not you can usually take it from what im guessing will also be a red with white trace running down the a pillar from the interior light.
The wire will go to earth when the door is open, i test this with a test light by connecting one end to 12v power and then the other to the door wire... it should light your light up with each door you open.
When in doubt, down and out.
soopachargen
