pretty sure the parcel shelf (metal part) is considered structural.
Is it possible to get the holes enlarged? or is this a definite no no?
DeeCee wrote:in these types of situations, I've used a larger speaker ring and let the speaker basket taper into the hole.
what speaker and hole size?
new_breed wrote:DeeCee wrote:in these types of situations, I've used a larger speaker ring and let the speaker basket taper into the hole.
8" and 6" hole
the thing is that if i raise the speaker up too much i wont be able to screw it in, unless i take the back glass out.
sergei wrote:In some instances you can mount them under the metal parcel, and keep stock speaker covers.
Just comes down to the system that raises the boot. i guess this is for a Silvia? And don't they use torsion bars like a corolla? in which case they run across the parcel shelf and will hit the speakers if you mount them below.Malcolm wrote:sergei wrote:In some instances you can mount them under the metal parcel, and keep stock speaker covers.
I like this one
RS13 wrote:Pretty sure you're allowed to modify speaker holes as long as its' at least 150mm from a seatbelt anchorage point? Might be more, I know you can't have structural corrosion/damage within 300mm of a seatbelt anchorage point. I had this with my AE101, I found that the parcel tray had been hacked up for 6x9s, took it to a VTNZ and they said it would need to be measured.
VIRM is your friend.
