cutting holes in parcel tray?
Postby deaf_rattle » Thu Sep 22, 2011 11:34 pm
pretty sure the parcel shelf (metal part) is considered structural.
Is it possible to get the holes enlarged? or is this a definite no no?
Postby DeeCee » Fri Sep 23, 2011 8:23 am
in these types of situations, I've used a larger speaker ring and let the speaker basket taper into the hole.
what speaker and hole size?
GT Four Adovansu
DeeCee
Postby deaf_rattle » Fri Sep 23, 2011 11:17 am
DeeCee wrote:in these types of situations, I've used a larger speaker ring and let the speaker basket taper into the hole.
8" and 6" hole
the thing is that if i raise the speaker up too much i wont be able to screw it in, unless i take the back glass out.
Postby RobertC » Fri Sep 23, 2011 11:53 am
8" and 6" hole
Ive have warnings of wof sheets for the holes the previous owner had cut. But they didn't do anything about it (vtnz).
To get around removing the rear glass. I found the best option was to bolt/screw the speakers to some mdf spacers. Then from the bottom side (in the boot) attach the spacers to the parcel shelf, a few self tappers should do the trick.
RobertC
Postby sergei » Fri Sep 23, 2011 12:10 pm
In some instances you can mount them under the metal parcel, and keep stock speaker covers.
Postby 1I1 » Fri Sep 23, 2011 12:41 pm
Mate who brought my old EX Lancer thought he'd fit some 6x9's in the rear - cut the holes (factory 4" I think) to suit then failed the first WOF he took it for.
I'd do what Rob has mentioned if you really want to have 8" speakers. Plus looks tidier IMO have stock speaker covers.
TRD Clicky >>Here
1I1
Postby Malcolm » Fri Sep 23, 2011 12:47 pm
sergei wrote:In some instances you can mount them under the metal parcel, and keep stock speaker covers.
I like this one
Postby RobertC » Fri Sep 23, 2011 12:59 pm
I like this one
Just comes down to the system that raises the boot. i guess this is for a Silvia? And don't they use torsion bars like a corolla? in which case they run across the parcel shelf and will hit the speakers if you mount them below.
Suppose you could always remove them though and use a stick to hold the boot open.
RobertC
Postby deaf_rattle » Fri Sep 23, 2011 2:56 pm
yeah, for s14 silvia.
Wont work underneath the tray and i think it would be abit silly having an 8 inch speaker sitting under a 6" hole.
I would prefer to keep stock grills if possible cause i wanna be all up in that.
Might just have to get some decent 6" junk to put in my trunk.
what do people recommend in the way of 6/6.5s these days?
Postby RS13 » Fri Sep 23, 2011 3:46 pm
Pretty sure you're allowed to modify speaker holes as long as its' at least 150mm from a seatbelt anchorage point? Might be more, I know you can't have structural corrosion/damage within 300mm of a seatbelt anchorage point. I had this with my AE101, I found that the parcel tray had been hacked up for 6x9s, took it to a VTNZ and they said it would need to be measured.
VIRM is your friend.
RS13
Postby vr4boy » Fri Sep 23, 2011 6:00 pm
get some soundstream sst6.5's, such an awsome speaker.
1995 ae101 levin st 20v
vr4boy
Postby GTsedan » Fri Sep 23, 2011 8:31 pm
RS13 wrote:Pretty sure you're allowed to modify speaker holes as long as its' at least 150mm from a seatbelt anchorage point? Might be more, I know you can't have structural corrosion/damage within 300mm of a seatbelt anchorage point. I had this with my AE101, I found that the parcel tray had been hacked up for 6x9s, took it to a VTNZ and they said it would need to be measured.
Some times it depends who you go to. My HQ got failed for this on the last WOF before I pulled it apart, it doesn't even have seatbelt mounts on the parcel shelf. It's good practice not to cut it either way.
GTsedan
Postby Lurkin » Sat Sep 24, 2011 2:04 pm
last ae101 had the parcel shelf hacked and had to get it repaired for a WOF...
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
