Devils Angel wrote:uve got ma vote i think its a g8 idea
B1NZ wrote:Devils Angel wrote:uve got ma vote i think its a g8 idea
Haha, i think you've been thinking of the farmers too much!
BlakJak wrote:Usually its
1 or 2 informal warnings.
1 Formal Warning
Suspension and/or Permanent Removal from the forums.
Basically it depends on the severity of the offense and the attitude of the offender. One-size-fits-all doesnt work.
BlakJak wrote:Its not quite this cut and dried.
Usually its
1 Formal Warning
- and its only happened two or three times in total since we started.
That said, Falco and Parker are both currently suspended.
Huffer wrote:BlakJak wrote:Usually its
1 Formal Warning
I think that it does work actually. If you lay the rules down right from the start (as you have in the new members sign up form) then there's no excuse for any immature or abusive behaviour.
I think the process you've listed above sums it up just fine - should there be enough VALID complaints about a member, then it's the moderator/admin job to deal with an unsavoury part of the community. Thankless job yes, but much appreciated nonetheless.
The 3 strike rule works just fine on ClubSub - we had an issue with a new member basically swearing a lot in posts and attacking established members because their views were different to his/her. They got a warning, had their posts edited/removed, and have since cleaned up their act.
At the end of the day it's up to the mods to decide what kind of site they want to look after - one that treats everyone equally and without bias/disrespect and promotes good informative discussion; or one that allows juvenile behaviour to distort what could be a welcoming community.
I'm only posting on here because I met a friendly member (SEXYRZ), and because there is a decent level of intelligent discussion MOST of the time. If it gets worse, I'm outta here.
Please don't let the forums degenerate into slagging matches.
It's just not cool.
BlakJak wrote:Disclaimer: Thoughts here are mine and dont represent The Admins, Mods, or TS in general.
BJ.
SilverAngel wrote:there are plenty of instances where we all make bitchy comments to each other on here and to outsiders could be mis-interpreted, therefore leading to an unfair suspension.
Silent Knight wrote:yea i'm all for the disciplinary thing.
But the way i see it is 3 counts out won't work because there are allot of times when people abuse each other in the good sence of the word. If something like this ever came into place there shoud be a combined decision made from at least 2 mods wether or not the "culprit" is indeed having a bit of harmless fun or they are abusing other people purely because they want to stir sh*t.
