Cams for a 4agze ae92
Postby Fred » Fri Apr 09, 2004 11:40 am
Hey guys wanting to know if its a good idea to chuck in sum blu top cams from an fxgt into my ae92 sc?
From my understanding it shud increase the puling power up higher with a small sacrific down low?
i know sumone who put them in his and after a dyno run torque was way way smoother but a lil lower than before.
Any sugestions?
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby 88gtz » Fri Apr 09, 2004 12:48 pm
I asked this same question on Club4ag a while ago and heres the reply i got
"I would not bother with bluetop cams, don't waste your time. If you want to do it right, put some good quality aftermarket cams. "
I know Kelford do some cams for the 4agze maybe you should talk to them http://www.kelford.co.nz/
88gtz
Postby madaz_18 » Fri Apr 09, 2004 3:33 pm
I got some reprofiled ae92 4agze camshafts that I put in my ae92 turbo 4agze engine. The engine revved heaps better that the original camshafts and the car was noticably faster but the car wouldnt idle very well and would splutter when driving at a constant speed. This was because the camshafts were affecting the vacuum which was playing havoc with the MAP sensor. My options were to get an aftermarket computer which would fix the problem or simply replace the cams to original. I took the latter option as after rebuilding my motor I didnt have the cash to put in a aftermarket computer.
If you are considering a new computer or have a AFM sensor, then reprofiled camshafts definitely supply easy power gains.
Mine are for sale $200 if interested. They cost $340 at kelfords.
jeff
0210335270
1989 Levin Gt-Apex
1991 Levin Gt-Apex
1990 Levin Gt-z Turbo B005TN
madaz_18
Postby Fred » Fri Apr 09, 2004 10:12 pm
its easy to change cams so will just try bluetop ones out and see what happens and if there is good gain may get aftermarket ones.
Fred
Postby PumpN » Sat Apr 10, 2004 12:20 am
Fred wrote:its easy to change cams so will just try bluetop ones out and see what happens and if there is good gain may get aftermarket ones.
not really, to do it properly you will have to re-shim all the tappets, which is a pain, its not as simple as an out and in job
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby Fred » Mon Apr 12, 2004 5:00 pm
wat happens of u dont re-shim the tapets? cud that b y no great results were achieved with a straight swap?
im sure guy i know did a straight swap
Fred
Postby PumpN » Mon Apr 12, 2004 5:59 pm
Fred wrote:wat happens of u dont re-shim the tapets? cud that b y no great results were achieved with a straight swap?
if you dont check the clearances then your selling yourself short (i wouldn't say your wasting your time but you wont get the most out of them), they might be sweet, they might not, and they will more than likely vary between cylinders, you will loose both lift and duration as the bucket isn't following the profile of the cam, its only being pushed down by the tip (extreme example i know)
PumpN
Users browsing this forum: Google [Bot] and 26 guests
