Adjusting timing with electronic ignition
Postby Lloyd » Wed Apr 28, 2004 6:48 pm
Hey all, just curious how exaclty you do this on say a 4AGZE.
Postby Ae92typeX » Wed Apr 28, 2004 6:53 pm
I dunno if its the same as the 4age so I wont post it up unless someone can confirm??? (too much writing)
But...basiciall you have to put a jumper in the diagnostics plug and then just adjust distributor angle as per.
anyone confirm its the same jumper???
Ae92typeX
Postby Lloyd » Wed Apr 28, 2004 7:01 pm
Adjust distributor angle.... with no distibutor?
Postby Ae92typeX » Wed Apr 28, 2004 7:03 pm
thats what I get for not reading properly!...I thought you just meant electronic points, not distributorless.
I guess its all done by computer??
Ae92typeX
Postby Bazda » Wed Apr 28, 2004 7:39 pm
well on the eng is this thing hanging off the side near the exhaust manifolds. think it's called crank angle sensor.
u have to put a wire between te1 and e1 in the diagnostics box, i think they are to 2 wires. The u get a timing gun and hook it to any of the leads with power and ground, then u read off it down the bottom of your pulleys.
loosen the 12mm bolt that holds the sensor in place, anit-clockwise advances the timing, clockwise retards the timing.
prob u wanna get a mechanic to do it.
Postby Lloyd » Wed Apr 28, 2004 7:45 pm
Sweet as, thanks guys
Postby Ae92typeX » Wed Apr 28, 2004 7:48 pm
Oh well, take away the word distributor and I was there!. I didnt realise the genII on 4agze's were distributorless...cool.
Ae92typeX
