heat shield removal
heat shield removal
Postby fatgtr » Thu May 06, 2004 5:41 pm
hey there
my celica has a heat shield covering the exauhst manifolds. it looks dumb and i want to know if it can be removed.
James
gotta love the punk music
fatgtr
Postby voiceinsideyou » Thu May 06, 2004 6:34 pm
Won't it be keeping hot air from entering your intake to some extent, however? (uneducated guess)
voiceinsideyou
Postby PumpN » Thu May 06, 2004 6:59 pm
go right ahead, but be prepared burn the paint off the bottom of your hood, and if its really hot then the top as well, and to add insult to injury it will heat soak the rest of your engine bay, say goodbye to cold air
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby fatgtr » Thu May 06, 2004 7:01 pm
na na its located where the manifolds exit the engine. i think it stops the heat from burning your hands if you touched them for some reason. it just looks silly. and i dont want hot air in the manifold anyway. cold is betta.
James
fatgtr
Postby fatgtr » Thu May 06, 2004 7:05 pm
perhaps if i do remove it and buy and aftermarket bonet with air scoops on it to cool it down? like a gt4 bonnet. its just in the way and would be easier to turbocharge it if it were gone.
James
fatgtr
Postby Crimson Tears » Thu May 06, 2004 7:16 pm
When the exhaust gases are hot they actually flow better, which means that the exhaust gases will leave the exhaust system faster which in turn means more power. You don't want to cool the exhaust manifold down because you will slow the exhaust gases down.
Crimson Tears
Postby fatgtr » Thu May 06, 2004 7:18 pm
yeah i also dont want to fry the paint on my bonnet. i think thats why it is there. either that or to stop someone burning them selves
James
fatgtr
Postby Twolitre » Thu May 06, 2004 7:33 pm
It's not there to stop people burning themselves, the heat shield will still do a good job at that, don't believe me? Do try it.
It's there to keep the heat around the manifold area so that it doesn't heat up the engine bay too much which in turn can damage your wiring loom, sensors, alternator etc
If you don't like the look of your heat shield you could get it HPC coated/polished or heat wrap the factory extractors if you have an ST182 Celica GTR
Twolitre
Postby Ae92typeX » Thu May 06, 2004 8:19 pm
on the mention of heat wrap...where on the northshore auckers has this and whats the approx $$?
Ae92typeX
Postby PumpN » Thu May 06, 2004 9:45 pm
Ae92typeX wrote:on the mention of heat wrap...where on the northshore auckers has this and whats the approx $$?
dont know about north shore (my auckland geography skills suck) but its common knowledge that segedins on dominion road do a ripping trade, what ever you do dont buy from repco (ripco), if your after it really cheap then i hear the best bet is to find a plumbing/home ventilation specialist as they sell the stuff bulk for good prices, its basically asbestos weaved into a fabric (correct me if im wrong)
PumpN
Postby Jools » Fri May 07, 2004 1:18 am
Wrong :)
It says "contains no asbestos" on the instructions
Cost me $15.97 for 2" x 10FT roll and $26.87 for 1" x 25FT roll from Segedin a week ago.
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Postby pc » Fri May 07, 2004 3:20 pm
Road and Track in Lower Hutt sell a heat wrap that is made of woven glass fibre for $11 per metre. They recommend painting it after wrapping to keep water from getting in and rusting the headers. turns out to be quite an expensive exercise with the can of HiTemp paint being $27
pc
Postby Jools » Fri May 07, 2004 4:04 pm
Yeah the stuff they sell at segedins says you need to use a heat proof paint on the pipes before hand to prevent rusting and to help the tape to stick to them.
But you can buy cans of high heat spray paint from most autoplaces for reasonably cheap.
Oh and on the heat sheild removal subject, dont do it unless your gonna shield the exhuast manifold, 'cause without it your altenator wont last more than a few months
90 Celica GTR Turbo
www.Jools.tk
Jools
