installin a monster tach!
Postby O2EAZY » Fri May 28, 2004 1:49 pm
hey guys i have a auto gauge monster tach to put in my car but the way i no how to put them in is to the exsitin rev counter! but in my car i dnt have 1! which has cause me a problem i dont no how to hook it up any help would b apprecated
bounce all da way home!:)
R.I.P 1990 toyota corolla sadan! lowered on 17's chromes n 1 week before getting paint she got stolen n writin off! thanks CAR THEFF! :(
its a sad day on da shore
O2EAZY
Postby PumpN » Fri May 28, 2004 1:55 pm
single coil ignition?
if so then there should be a wire running from the coil to the dizzy, you seen to get a feed to the tacho off this wire and use that as your signal for the tach, you will also need an earth and maybe power which you can just tap into the stereo for
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby O2EAZY » Sat May 29, 2004 11:29 am
cheers bro but 1 more question do u go off the negitive or positive??
O2EAZY
Postby PumpN » Sat May 29, 2004 11:38 am
O2EAZY wrote:cheers bro but 1 more question do u go off the negitive or positive??
what do you mean? just tap the negative and positive into the negative and positive running to your stereo
PumpN
Postby strap-on » Sat May 29, 2004 12:03 pm
i think he means which wire on the coil, u take it off the negative wire on the coil
strap-on
Postby O2EAZY » Sat May 29, 2004 8:51 pm
thanks 4 the help guys its going in 2moro!! thanks
O2EAZY
Postby RS13 » Sun May 30, 2004 1:34 am
Ya know, just as a side note, I stuck a monster tach with shift light into my 2K starlet, every time I'd rev it to hit the shift point (which was only like, 4000rpm), the light would come on, but the car would die.. :D hahah!
RS13
Postby O2EAZY » Sun May 30, 2004 1:13 pm
haha guts! dead car cause of a monster! suck :roll: guys the wires leading up to the dizzy which one is the negative?? ones a black wire n the other a black wire with an orange strip on it! sorry must b causin u guys pain! :?
cheers for the help!
O2EAZY
Postby PumpN » Sun May 30, 2004 1:17 pm
O2EAZY wrote:haha guts! dead car cause of a monster! suck :roll: guys the wires leading up to the dizzy which one is the negative?? ones a black wire n the other a black wire with an orange strip on it! sorry must b causin u guys pain! :?
the one which goes from the dizzy to the coil
PumpN
Postby strap-on » Sun May 30, 2004 2:43 pm
oh for a second there i was gonna say eh? i thought u mean the HT lead, lol u defintly dont wnna tap into that one, there will be a real thick wire going from the top of the coil to the top of the dizzy,and then out of the thin wires one should go back to the bottom of the dizzy somewhere, my guess is it will be the straight black wire, but what i would do is test it by hooking up the possitive and negative to the battery, and then puuting the signal on on both the wires coming oput of the coil, it will only work on one of them.
im not sure if pumpn mentiond it before but the fourth wire is the switched illumination wire, and to hook that up u have to find the wire, there will be one either behind ur stereo, or have a look at ur clock, if it dims when u turn the lights on then theres a switched illumination supply there too
strap-on
Postby PumpN » Sun May 30, 2004 4:11 pm
ooooohhh, yeah my bad should have been more specific, not the HT lead, thats a big no no, should be a fine as wire which runs from the side of the dizzy to the side of the coil, dont touch the big insulated ht lead unless you wont to run 10,000 volts through it
PumpN
Postby O2EAZY » Tue Jun 01, 2004 5:32 pm
cheers for the help pumpn n every1!! got it going this was a wire comin out of the dizzy that would b for a standed tacho but of cause i dnt have 1 so i tapped it into that!!!:) n i just ran the back lights of my cig lighter!!! it goes sweet!!! thanks guys
wade
O2EAZY
Users browsing this forum: Bing [Bot] and 4 guests
