Rollux wrote:Quest 4 were using a V6 Surf box in there 1UZ powered beasty. The V6 box is a lot beefier and has a better ratio spread than the diesels
Shady_Dan wrote:Rollux wrote:Quest 4 were using a V6 Surf box in there 1UZ powered beasty. The V6 box is a lot beefier and has a better ratio spread than the diesels
Was that before or after the 6 speed supra box they put in there ( I assume ur talking about the GRND0 ute here...), my knowledge is a little rusty here, but from memory didnt it used to be an auto that they used to tow their drag starlet with till they decided to do the air bagging, drop the lexus 1UZ in it and new gearbox? like i said if im wrong so be it, but i just thought they were using a supra box...
rcook_nz wrote:you have got my attention now im wondering bout that v6 box any ideas if it would go ith the 1g and what sorta work would be involve using it instead of a supra box
rcook_nz wrote:hay i was just wondering if when doin a hilux conversion if it is easier or harder if u start out with either petrol or desiel motor
im think of putting a 1g gze in to a hilux and have found a good candidate for the conversion but its desiel so will this pose any problems at all?
