So first you modify the exhaust and intake and you raise the boost pressure. Then you adjust fuel settings and raise the boost pressure. And this goes on and on and on. Until the car is dead
RAZA wrote:just follow the instructions in mrozio's signature.So first you modify the exhaust and intake and you raise the boost pressure. Then you adjust fuel settings and raise the boost pressure. And this goes on and on and on. Until the car is dead
Oizo rules, that there sums it all up.
Mmm, Boost wrote:Big front mount, exhaust and intake, and either a FCD or full aftermarket ECU and boost controller. Ought to put a smile on your face
fivebob wrote:Mmm, Boost wrote:Big front mount, exhaust and intake, and either a FCD or full aftermarket ECU and boost controller. Ought to put a smile on your face
And a big hole in your wallet from the impending self destruction of the engine
My recommendation would be to start with the ECU (preferably Motec) first, add water injection, then a big FMIC and better Turbo.
Whatever you do, don't turn up the boost on the stock ECU and expect the motor to last
Mmm, Boost wrote:I am well aware of the effects of too much boost on stock ECU Somehow my first engine boosted over the fuelcut
Motec is a bit over the top isn't it? LinkPlus works fine for me so far (Not that I'm making much power)
Users browsing this forum: Google [Bot] and 71 guests
