HIGH idle
HIGH idle
Postby Red2 » Fri Jun 04, 2004 3:19 pm
Car is a n/a sw20 mr2
The idle seems to be 1200-1500 even when warmed up.
No mods on car.
What i wanna know is,
What can be casuing this?
How to fix it?
Is it anything serious?
Red2
Postby levin_it_large » Fri Jun 04, 2004 3:29 pm
i have this same problem on my AE111 levin
everyone says that it is because of a vacuum leak check around your air filter
levin_it_large
Postby AXNGRL » Fri Jun 04, 2004 3:46 pm
My starlet had that issue too, however the throttle body had just been cleaned. It turns out one of the paper gaskets had a break in it...
AXNGRL
Postby Dr-X » Fri Jun 04, 2004 7:49 pm
check all vacuum hoses between you air cleaner and your tb. Check throttle position sensor. Remove and clean tb completely, including idle stepper motor.
Dr-X
Postby Andy from the block » Fri Jun 04, 2004 8:54 pm
Have u adjusted the screw that controls the idle thingy?
1200-1500rpm? thats not even that high compared to my car...on cold start mine is like 2100rpm and when warm around 1500
Andy from the block
Postby Red2 » Sat Jun 05, 2004 1:21 am
No i havnt really, since i only got the car two days ago and i aint too mechanical minded
Is it even a serious problem having it idle at that rpm?
Red2
Postby Dr-X » Sat Jun 05, 2004 1:30 am
not usually a biggy, not too much of a worry.
If you're quite concerned, take it to a mechanic, it'll be an easy and cheap fix, just go to a good mechanic you trust. :twisted:
Dr-X
Postby LowRydr » Mon Jun 14, 2004 7:08 pm
my car idles at like 1500 i like it that way, better throttle responce as its already up the rev range
///TRD Toyota Racing Development
take a really hardcore project idear, making it a reality? .....im 70% there
LowRydr
