Question: Toyota Curren, what do these buttons do?
Postby VTEXTC » Tue Jun 08, 2004 9:10 pm
Hey guys,
My mums just got herself a 1997 (i think) Toyota Curren, 2l SOHC i believe, Auto.
Anyway, next to the Auto Gearlever ther is a button that if pressed, a light on the dash showing this
ECT-S
PWR
in green, and if the switch is pressed the other way,
ECT-S
MAN
(i think)
in orange
What exactly does this do? Also if you press it in the middle they both turn off. Just curious as to what it means, and does.
One more button, just above these two, is a Red buttin with some Japanese writing under it, when pressed doesnt appear to do anything at all.
Being a Honda boy im not to certian about the Toyota stuff.. and thort Toyspeed be a good place to start :)
Anyone know?
Cheers Guys
VTEXTC
Postby Da_K » Tue Jun 08, 2004 9:44 pm
Yeah, I've got the same setup on my car, even though it is a Cynos :P
The red button with the Japanese writing on it is for changing gear if required when the key is not in the car.
My understanding of the Power & Manual buttons is how quickly the car accelerates before changing into a higher gear.
Correct me if I'm wrong
Jared
Da_K
Postby celica_tommo » Tue Jun 08, 2004 10:41 pm
yeah... thats basically right...
red button with jap writing means you can move the shifter without the key
ECT stands for Electronic Controlled Transmission... and pwr is power man is manual
power will stay in lower gears longer... more sporty, better acceleration and man is the opposite
celica_tommo
Postby Adamal » Tue Jun 08, 2004 11:07 pm
Also, I'd say it's highly unlikely to be a SOHC :)
Postby dohca » Wed Jun 09, 2004 12:49 am
the ect manu is for snow or other surfaces that are slippery basicly holds it in a lower gear so it doesent spin to start off with.
dohca
Postby Shady_Dan » Wed Jun 09, 2004 5:15 pm
Adamal wrote:Also, I'd say it's highly unlikely to be a SOHC :)
quite right there, as far as i know all currens are 2.0L dohc 16v.
boss has one, took it for a blat, not bad cars, but i dont like the stylin, doesnt know whether it wants to be a levin or a celica, so it gets moulded to look like both :P
Shady_Dan - Keeping skanks in check since 1999
"Whats the difference between God and the Mt Maunganui police?"
"God doesnt think he's the Mt Maunganui Police"
Shady_Dan
Postby Dr-X » Wed Jun 09, 2004 6:27 pm
Not quite. Power allows the rev's to get higher on full throttle before changing gear, and also changes down more readily on acceleration.
Manual mode is just a mode that allows you to select which gears to use. For example, if you put it in 1, it'll start in 1 and will rev until it hits the limiter. If you put it into 2 you'll start in 2 and stay in 2. If you put it in drive, it'll drive drive really conservatively.
Dr-X
Postby VTEXTC » Sun Jun 13, 2004 11:15 pm
hey Cheers for that guys! Great help.
I spose it could be a DOHC it just looks a bit small..
heh
Yeah its not a bad car to drive, nice and smooth, got enuff power for mum haha.. bit of a downgrade from the 3.0 V6 Maxima tho..
Ah well Thanks!
VTEXTC
Postby Dr-X » Sun Jun 13, 2004 11:35 pm
when i first got my 'yota (Carina ED) i thought it was a sohc because of it's size (knowing nothing about 3sfe motors) but yeah they're just a very small dohc head :D
Dr-X
Postby pidge » Mon Jun 14, 2004 11:18 am
Dr-X wrote:when i first got my 'yota (Carina ED) i thought it was a sohc because of it's size (knowing nothing about 3sfe motors) but yeah they're just a very small dohc head :D
The Toyota FE head (regardless of what block it is on) is the "Economy" cylinder head, with a small angle between the inlet and exhaust valves. The GE head is the performance head, with a larger angle between the inlet and exhaust - which is why is is much wider.
The Totoya V6, V8 and V12 engines all have FE heads because it's a bit tricky to get the fat GE heads on and be able to do the intake plumbing nicely.
hmmmmmm 1GZ-GTE (5L, V12, twin tubo....) if only....
pidge
