Digitash to Normal Dash
Postby Silent Knight » Wed Jun 09, 2004 12:39 pm
I was wondering if were to get my hands on a normal dash eg. not a friggen diggy dash for my GA70 supra would all the plugs and everything fit in the right spots so i can just do a straight swap if i can find a normal dash out of same model and year supra?
Hanré
Silent Knight
Postby deaf_rattle » Wed Jun 09, 2004 1:05 pm
dont do it, digi dash's are wicked :D
Postby Silent Knight » Wed Jun 09, 2004 1:47 pm
no i absolutely hate my digidash
i want a gud old normal one;)
Silent Knight
Postby AceSniper » Wed Jun 09, 2004 2:29 pm
talk to The_Fallen he got his hands on one its yet to be put in but the plugs are diffrent... so its just not a strate plug swap
AceSniper
Postby the fallen303 » Wed Jun 09, 2004 2:31 pm
hey, yeah, it's not a straight plug in swap. the wiring and the plugs themselves are completely different, you also need the analog fuel sender as this is also different. there are probably more things that are different, but we haven't found them yet. so yeah, it's not an easy swap.
true house of JZ
Stay true to the origin
the fallen303
Postby Silent Knight » Wed Jun 09, 2004 3:04 pm
so this would be easier to do once i do the 1JZ conversion with loom and ecu and everything swap over and jst get normal dash out of a 1JZ?
Silent Knight
Postby Ae92typeX » Wed Jun 09, 2004 4:10 pm
Silent Knight wrote:so this would be easier to do once i do the 1JZ conversion with loom and ecu and everything swap over and jst get normal dash out of a 1JZ?
probably, but like said above you will still need the correct fuel sender also
Ae92typeX
Postby Silent Knight » Wed Jun 09, 2004 4:24 pm
yipyip will keep that in mind.
thanks for all your help fullas :D :D
much appreciated
Silent Knight
Postby the fallen303 » Wed Jun 09, 2004 9:27 pm
when you do the conversion, you will not be changing the entire loom, only the engine loom, which is seperate. you have to remove the entire dash and most of the interior to change the main car loom (been there, done that, not fun). you are going to have a mission wether you do it at the same time as the conversion or not, the two are not really related.
true house of JZ
the fallen303
Postby Malcolm » Wed Jun 09, 2004 11:01 pm
the loom for the dash actually comes out quite easily. There are a couple of plugs on the driver's side kick panel area (you know, where all the fuses and shite are), and I think there was one on the passenger's side too. All you really need to do is unplug the loom in these places, unbolt the dash and remove it. I'm sure there were a few other things you need to do to remove it, but that's basically it. From there I think it is a case of swapping the analog dash wiring loom onto your dash, reinstalling, plugging everything back in an plugging in and installing the analog dash. Aswell as the fuel level sender, you need the speedo cable from the analog dash. I should note I haven't actually done the swap from digital to analog, but I had a digital and an analog supra at the same time and pulled the dashboards out of both (and reinstalled the analog one).
