Modifying Driveshafts?
Postby celica_tommo » Fri Jun 04, 2004 12:01 am
whats involved in shortening a driveshaft?
is the only way to get splines cut further down it and the end cut off or can they cut it in the middle and rejoin it somehow
basically I need to know what kinda price I should expect and whatever you know about how they do it
also anyone know of any good machinists/engineers to do it around the Palmy area?
celica_tommo
Postby celica_tommo » Wed Jun 09, 2004 11:45 pm
celica_tommo
Postby rxtoy » Thu Jun 10, 2004 6:02 pm
for RWD:
don't know of anywhere to do it but basically you give them your input and output end, tell them the length you want it, how many universals, etc and they weld it up and balance it.
its not the sort of job you should be doing at home though
for FWD????
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby rxtoy » Thu Jun 10, 2004 6:04 pm
for RWD:
for FWD????
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby celica_tommo » Thu Jun 10, 2004 6:48 pm
yeah, fwd but it's basically the same idea... specifically modifying though
celica_tommo
Postby rxtoy » Thu Jun 10, 2004 10:01 pm
fwd driveshafts are pretty different to rwd driveshafts, thats not to say they can't be modified. why do you want to shorten them????
i know its been done before, can't think off hand of who's done it though.
i think you'd probably have to have something custom machined up unless there's something from a different vehicle that will fit.
what are they for?
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby celica_tommo » Thu Jun 10, 2004 10:09 pm
its to adapt gearbox and driveshafts to another vehicle... I'm just wondering if they machine the spline down the shaft at the cvs to do it or use some other technique
celica_tommo
Postby Bazda » Thu Jun 10, 2004 10:50 pm
up here in aucks, precision engineering shortens them for like $90 each
Postby celica_tommo » Fri Jun 11, 2004 10:13 pm
hmmmm... bout what i thought
celica_tommo
Postby celica_tommo » Fri Jun 18, 2004 2:42 pm
for future reference I eventually found after ringing around that Motor Machinists in Palmerston North does it
They shorten it by actually cutting it in the middle and welding it back together and balancing.... was quoted $180 for the two
celica_tommo
Postby Snoozin » Fri Jun 18, 2004 4:07 pm
Another lot you can try is Manawatu Hydraulics, a mate of mine works there, and he always talks about how he re-splines axles etc etc. and even makes some from scratch!
May cost more though if another spline has to be machined!
Snoozin
Postby KE10 door slammer » Sat Jun 19, 2004 3:50 pm
gear cutting services in auckland did mine on my mx5 for $75 each including heat treating
KE10 door slammer
Postby celica_tommo » Fri Jul 02, 2004 6:10 pm
well now I'm pissed off :evil:
after checking up with motor machinists that they do actual shorten driveshafts and discussing with them how they do it and a price I took my driveshafts in today to get them done and guess what?... of course they dont do it any more. $&#$% bastards
So I'll be trying your guys suggestions... keep them coming
Also if anyone has some driveshafts lying around I might be interested in them especially if you have some supercharged GTZ levin/trueno ones... dont really need the cv joints either
celica_tommo
Users browsing this forum: Google [Bot] and 25 guests
