Changing Springs
Changing Springs
Postby z|gen » Sat Jun 12, 2004 3:02 pm
Hey guys
my awesome as KE30 has cut springs on the front, and flipped leaf springs on the rear, now, how hard is it to change the front springs over and what tools will i need and how hard is it to flip the leaf springs back over, is this something which i could do on my driveway with a bit of time or would i be better off waiting till i can get hold of a hoist or paying someone to do it ?
cheers David
AE91 SUPERCHARGED COROLLA
z|gen
Postby Dell'Orto » Sat Jun 12, 2004 3:37 pm
The front springs are an easy enough job, you should be able to do this in an afternoon in the driveway. Even though the front springs have been cut, you'd be safer getting a spring compressor to squash them down to taken them off the strut.
Leafs will be a bit tricker, but they're less likely to take your head off when you unbolt them :lol: It'll be a good weekends work for you all up dude.
Postby badidas » Sat Jun 12, 2004 6:13 pm
yeah and you can do it without spring comressors but its trick and dangerous better off getting $15 compressors than loosing a head
shouldnt take more than a few hours
tools you need are:
compressors for the springs
14 mm 17 mm 12mm spanners
2 sisor jacks or a trolley jack axcel stands
wheel brace ( the cross one )
1989 mazda bongo aka [BNGBUS]
badidas
Postby PumpN » Sat Jun 12, 2004 9:48 pm
spring compressors are $50 for ripco (i meant repco :roll:)
and you will need a power bar, either that or a good 1/2" drive socket set and a bit of steel pipe to use as a whorey extension (if it works then its not rangi)
other than that its a piece of pie, pretty much just spannering stuff
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby Ae92typeX » Sun Jun 13, 2004 9:21 am
or if ya cant afford compressors you could use a pack of thick cable ties!, dodge as hell, but it works.
[just like to point out I have and use compressors however]
Ae92typeX
Postby M R 2 Mk1 » Sun Jun 13, 2004 9:50 am
that blue plastic that they use to tie up pallets of shit is bloody strong and when used well is a great spring compresser
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby z|gen » Sun Jun 13, 2004 1:37 pm
sweet
cheers guys..might have to wait a couple weeks now :(..
ugh..
also, how hard would fitting a DX sedan or wagon rear end be into my ke30, would i need to change anything or should it just bolt straight up ?
cheers David
z|gen
Postby badidas » Sun Jun 13, 2004 1:41 pm
sedan dont have leaf sprung diff they have coils the wagons do have leafs (i think)
badidas
Postby z|gen » Sun Jun 13, 2004 1:47 pm
ahh k
so would a wagon rear end fit bolt straight up, or would i still have a problem with the leaf springs..?
z|gen
Postby Dr-X » Sun Jun 13, 2004 8:47 pm
bah you dont need spring compressors dont be such a bunch of wusses ;) Seriously, just point away from face and unbolt.
Dr-X
Postby Ae92typeX » Sun Jun 13, 2004 11:15 pm
Dr-X wrote:bah you dont need spring compressors dont be such a bunch of wusses ;) Seriously, just point away from face and unbolt.
Thats true for some cars- tx3's have barely any spring travel when unbolted- done them in my mates car no issue without compressors.
Mu uncles daihatsu's springs however get about 25-30% longer when off- Im not sure I'd just point them away when unbolting.
Ae92typeX
