drive shaft balancing?
Postby deaf_rattle » Sun Jun 13, 2004 12:32 am
I think im going to have to modify the dirve shaft to suit for the 7mgte conversion.
Is it fine to just cut off the bit i need and then re weld it onto the shaft i want? and then go get it balanced?
and where to i go to get it balanced?
how much does a balance cost?
Postby badidas » Sun Jun 13, 2004 12:37 am
i recon its best left to the professionals it will probably cost $200- 400 welded and balanced
1989 mazda bongo aka [BNGBUS]
badidas
Postby JamesM » Sun Jun 13, 2004 4:23 am
take it to driveinn.. in avondale.. real good and cheap too
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Ae92typeX » Sun Jun 13, 2004 9:18 am
Just got mine lenghtened and balanced at automotive drive line in sunnybrae rd glenfield. All up cost $330. nice job done.
If your a good welder & cutter you could do that bit by yourself and the balancing charge on mine was about $120 I think.
Ae92typeX
Postby Stealer Of Souls » Mon Jun 14, 2004 12:02 am
You should investigate how much to fabricate an entirely new light weight one... Never know might be worth the money...
'86 AE85.5 Levin
Stealer Of Souls
Postby Shotgun » Mon Jul 05, 2004 5:54 pm
Drive Inn, New Lynn. $230 to lengthen mine and put big ass Hilux uni in there.
Shotgun
