RWD gearbox types?
RWD gearbox types?
Postby matt dunn » Wed Jun 09, 2004 11:24 pm
What are the different types of RWD gearboxes that toyota make and what did they come out of.
I know..
T50 came behind 4AGE in AE86 and some celica's and behind 2TG's in some cases,
But W5* series and I think there is a G something series box aswell?
And the R154 I thought was the 5 speed out of the latest shape supra but someone said they came out earlier than that. Are they still the same box?
Thanks for any info.
Matt
Postby evil_si » Wed Jun 09, 2004 11:59 pm
the r154 is the big daddy, hard to get and really strong, from late 80's early nintys supras, from what i under stand,
w58 is from a supra as well, there are new and old versions depandant on which model car, apparently the latest w58 is really strong
as for the others in the w series im not sure
evil_si
Postby rxtoy » Thu Jun 10, 2004 5:56 pm
there's also a P50 (and P40???), i've only seen one once in a TT132 corona station wagon behind a 2T. apparently they're fairly strong, same bellhousing as a T50 and same output spline (20). fairly rare apparently though and i'm not sure on the length of them.
cheers,
Matt.
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby z|gen » Thu Jun 10, 2004 7:04 pm
and dont forget the mighty 'K' series
the K40 - 4spd starlys and rollas
and
the K50 - 5spd starlys and rollas and the 86 corolla levin (3A-U/4A-U some) i think, dont quote me on that though..
AE91 SUPERCHARGED COROLLA
z|gen
Postby matt dunn » Thu Jun 10, 2004 7:59 pm
So is there a G series box/
What came out in the 80's cressida's behind the 1GGE motors?
box
Postby crispy'86 » Thu Jun 10, 2004 8:15 pm
The cressidas have w series behind them, most likely w55, 57
crispy'86
Postby z|gen » Thu Jun 10, 2004 8:23 pm
the cressidas usually have the same or similar gearbox to the supras, depending on year i think,
and i believe the old toyota crowns also had the same g/boxes
z|gen
Postby Malcolm » Thu Jun 10, 2004 10:05 pm
good website, courtesy of Mark/AE25
http://www4.tpgi.com.au/users/loats/tec ... boxes.html
Postby NZ_AE86 » Mon Jun 14, 2004 11:04 pm
The G series box comes in alot of vans, it has the same gearset as a w series box. They are good for parts but no good for $&#$% all else as they are cable change!
NZ_AE86
Postby matt dunn » Tue Jun 15, 2004 12:58 am
NZ_AE86 wrote:The G series box comes in alot of vans, it has the same gearset as a w series box. They are good for parts but no good for f**k all else as they are cable change!
Thanks for that. So theres no way my box is a G it must b a W55 type.
Whats the differences between the ones with alloy centre and cast centre?
Is it just ratio's and which is better?
Postby KinLoud » Wed Jun 16, 2004 8:59 am
G series boxes out of hilux's have the shifter in the same place as the W series box. G series out of liteace or hiace have side shifter levers.
Ken
Taupo
021 408 863
