what is the standard boost for a st205 1996 celica? what psi and bar
i knew it at one stage but forgot
Zomb wrote:on gran turismo it says 6.257 bar
JiNX wrote:Zomb wrote:on gran turismo it says 6.257 bar
<g> That's 91.97psi, Hmm, would make around 10,000hp...
StarbuckST205 wrote:my apexi gives .8 bar as the default boost, however i suspect that the stock setting may be somewhere around .5 - .6
hope that helps
MrOizo wrote:StarbuckST205 wrote:my apexi gives .8 bar as the default boost, however i suspect that the stock setting may be somewhere around .5 - .6
hope that helps
is yours completly stock? like stock air filter (setup) and exhaust?
just curious
Users browsing this forum: Majestic-12 [Bot] and 53 guests
