Factory Tacho
Factory Tacho
Postby 7apples » Fri Jun 18, 2004 5:05 pm
ive got a really basic car - ee104 (it the ae101 wagon with a 5efe if you dont know what a 104 is) with no tacho voltmeter, i go a face plate out of a ae101 fxgt, every thing works apart from the tacho. theres no cable in the loom,
where do i hook the ig- to?? is there a sensor???
7apples
Postby krad » Fri Jun 18, 2004 5:57 pm
Isn't that somewhere on the ignitor?
I'm not sure :)
krad
Postby sprint » Fri Jun 18, 2004 6:00 pm
I once made a digital tacho and you hocked it up to the negative side of the coil. Therefore it counts the number of sparks. Worth a try.
Old Rides:
88 GZ20 Soarer 1G-GTE
81 Ex Lancer
sprint
Postby GTUWET » Fri Jun 18, 2004 6:11 pm
i got a ae100 wagon and it didnt hav a tacho in it i got an aftermarket 1 and ran a wire from the front of the diagnostic box works a treat 8) oh and its not on the inside just at the front
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby MrOizo » Fri Jun 18, 2004 6:13 pm
sprint wrote:I once made a digital tacho and you hocked it up to the negative side of the coil. Therefore it counts the number of sparks. Worth a try.
yeah agreed ;) well for aftermarket its the negative on the coil anwyyas..
MrOizo
Toyspeed Legend
Postby PumpN » Fri Jun 18, 2004 6:53 pm
generally is the negative side, not much kit takes to kindly to 10,000 volts :wink:
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby 7apples » Sat Jun 19, 2004 5:08 pm
all go now. thanks
How you like them apples??
7apples
