FLAWLES wrote:does any1 here have any tips on how to drive a car with a brass button clutch as i do not want 2 ride it or dump the clutch????
also does any1 here have one does the clutch feel soft is this normal
any help would be nice
Al wrote:Yeah when reversing you basically have to rev, let out clutch and as soon as it grabs put your foot back down on the clutch, dumping the clutch in reverse is a bit dogdy as i have found out
JasonZE wrote:At what point in the pedal travel does you r clutch engage if near the top as mine was I adjusted the pedal pushrod and stopper to get it down low as you only need a few inches of travel with the brass plate, the higher the pedal engages you seem to ride it as your foot comes off the floor giving less control (just what i found)
It all comes down to practice and adjustment.
FLAWLES wrote:JasonZE wrote:At what point in the pedal travel does you r clutch engage if near the top as mine was I adjusted the pedal pushrod and stopper to get it down low as you only need a few inches of travel with the brass plate, the higher the pedal engages you seem to ride it as your foot comes off the floor giving less control (just what i found)
the ae101 clutch control are hydraulic can you still adjus these how??
by what bleeding them???
cant remember what type of p=plate it is but it is a funny purple colour
and yea it does grap when the peadel travel is high
thanks for the help
Al wrote:Ive just clicked over a very fun 1000kms of wearing in my TRD 3 puck button clutch, best way is just to rev it and let go, like 1500rpm but thats on a pretty torquey 3s. And yeah try not to ride it from what ive been told it can warp the plate and one puck will grab before the rest
Out of my 20V turbo DX. Had to happen at the $ & R Champs diddn't it
10k 20v wrote:if it's from tony it will certainally be and exedy extreme pressure plate.
They are pretty good so you should have no probs with it
Users browsing this forum: Bing [Bot] and 54 guests
