not a big job but you need to unstitch the old one, weld on the new one
Mr Revhead wrote:and if you use all parts from an ae82 including brakes (if they are different
fronts could be the same) then no cert is needed cause you are just upgrading to factory spec.
deaf_rattle wrote:trd man is right.
My engine conversion everything bolted up, but i still need to get a cert.
slightly different example, but same principal
