Turboing a ae85
Postby NZ_AE86 » Thu Jul 01, 2004 7:18 pm
A shimmed dif will be ok for drifting and burnouts but for real racing you can not beat a good TRD or similar unit. But for outright tough a G series is great. Heavy but strong!
NZ_AE86
Postby suberimakuri » Thu Jul 01, 2004 7:34 pm
I doubt you'd notice a difference. ;)
suberimakuri
Postby Drifter4ag » Thu Jul 01, 2004 10:51 pm
its ok .. i understand you have put alot of money into your TRD LSD but how much money you spend on something does not necessarily make it a better item have you tried racing on a shimmed up G series ?
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Adamal » Thu Jul 01, 2004 11:09 pm
Screw turbo and go Formula Atlatnic :D
Postby PumpN » Thu Jul 01, 2004 11:14 pm
Adamal wrote:Screw turbo and go Formula Atlatnic :D
You obviously haven't priced any of that shiz out :? :lol:
You think the price tag for doing the turbo well is heaps?, I doubt you will get an atlantic speced short block for that
Although I really do love high revving NA engines
'92 Nissan 200SX, Need a Daily driver!!!
PumpN
Postby NZ_AE86 » Thu Jul 01, 2004 11:32 pm
Drifter4ag wrote:its ok .. i understand you have put alot of money into your TRD LSD but how much money you spend on something does not necessarily make it a better item have you tried racing on a shimmed up G series ?
Yes! I have raced on a standard Hilux shimmed diff and a standard AE86 LSD, Nothing is as good as a quaility LSD! What you don't realize when you are shimming a diff you are just putting more stress on the poor little clutch plates. Depending on how tight it is shimmed you will either get a tight as diff that does not break away on turning(great for drifting but you might as well weld it up!) or when it does break away it will not lock up as quick and predictably as an LSD designed for racing. The end result being that you will $&#$% the shimmed LSD!
But if your happy with what you have then stick with it, but when you come to do some real racing, get some real 'gear'. :!: :D
NZ_AE86
Postby Adamal » Fri Jul 02, 2004 6:55 am
I've got the price cataloug in American $$$. $4214.88USD for the crankshaft :?
But hey, dreams are free :)
Postby NZ_AE86 » Fri Jul 02, 2004 8:04 am
There was an Atlantic engine for sale for 10G about a year ago! You would get no change from 25G if you wanted to build a full Atlantic motor!
You can still build a reliable 200hp N/A motor for 10G but it would be no good for anything but track work.
Atlantic motor would be the shit though.
NZ_AE86
Postby 10k 20v » Fri Jul 02, 2004 7:45 pm
Umm, i know of 220hp 4ages in rally cars and also you can get 200hp on pump gas if you felt that way inclined.
10k 20v
Postby AE85.6 » Fri Jul 02, 2004 8:16 pm
sorry to be the diff model novice but,
k series ae85 standard ?
t series ae86 standard ?
g series hilux ?
e series ????
f series ????
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby RedMist » Sat Jul 03, 2004 11:32 am
NZ_AE86 That wasn't an Atlantic engine. For starters it was running FI, individual throttle bodies, and a common airbox. It was also running a non spec dry sump pump.
4age's can develop some serious HP NA, but they tend to be highly strung engines that are more than a bitch to run on a standard road. My 176bhp (wheels) NA engine only comes on cam at 5.5k RPM. That sounds quite low, however when you sit there and wait... and wait to get power it's very annoying! I have a custom made close ratio box that suits it well, however I end up having to row the gearlever constantly! The advantage is that I get very predictable power (shyte loads) and I can race in NA classes. A true Atlantic engine would be even more difficult to control.
I'd simply turbo a standard bigport if I wanted a bit of cheap power on the road.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby AE85.6 » Sat Jul 03, 2004 4:49 pm
g series hilux ?
e series ????
f series ????
also apart from discs and drum rear ends how else can i tell the 85/86 models apart ??? AE85 standard should be 6.75" ? and AE86 standard is 7" ?
any other signs someone mentioned number on bolts around the crown ?
AE85.6
Postby NZ_AE86 » Sun Jul 04, 2004 1:54 pm
RedMist wrote:NZ_AE86 That wasn't an Atlantic engine. For starters it was running FI, individual throttle bodies, and a common airbox. It was also running a non spec dry sump pump.
Sorry dude, must have been a different one that i saw, it was almost complete(only missing flywheel and clutch) , needed rebuild (at least rings and bearings maybe pistons too). Oh and I agree they would only be good for track work, far too peaky for anything else. I know you gear changing feeling too, we have a 190HP AE86 with a quaife dogbox, it is great but you are forever changing gears in it!
I have done some turbo engines and they go well but as you say N/A means you can race in class B.
NZ_AE86
Postby gdsup » Sun Jul 04, 2004 8:09 pm
NZ_AE86 i would be keen to go for a few laps grip racing with you, that is if you are keen to come out and drift with us, maybe at a manfield open day??
gdsup
Postby NZ_AE86 » Sun Jul 04, 2004 10:32 pm
Yeah, I would be keen to take you for some laps, but would it not be frowned upon at a drift day to not be drifting?
NZ_AE86
Postby gdsup » Mon Jul 05, 2004 9:08 am
yea i meant manfield open day, as they have both grip and drift sessions on the same day
gdsup
Postby NZ_AE86 » Mon Jul 05, 2004 6:35 pm
Sweet, send me pm with details and should be good.
NZ_AE86
Users browsing this forum: Google [Bot] and 27 guests
