UTERUS wrote:you have to try a few to get the right one.
AceSniper wrote:UTERUS wrote:you have to try a few to get the right one.
unplug the main plug... get a ecu diagram (heaps of them online just look) count how many pins along and you will get the right wire first time, dun butcher the loom.
UTERUS wrote:Excuse me but my loom is not butchered, i put a small cut in it and then taped it back up. You can't even tell its been tampered with.
corollamadness wrote:if i had this switch installed i would lose the ability to have VVT activated at its normal rates like after 4000rpms.
boyracer69 wrote:It will either be on all the time when the switch is "on" and when the switch is "off" means the ecu is controlling it the same as before
