Help!!!!! My car doesnt run properly :(
Postby starlet » Wed Jul 14, 2004 10:13 pm
Hey
well after replacing head gasket, fitting 2nd hand head with new valve seats and valve guides seals etc. My car wont run properly
Basically it starts and run at about 2000rpm when u hold throttle open that far, revs 2 rev limiter, but anything below sorta 2000rpm it wants to die and wont idle.
it sounds like it is running on about 2-3 cylinders but im unsure, is fuken gutless when trying to drive.
So any ideas to try? basically ive checked cam timing is ok, disi is in correct place on cam, plug leads r on correctly, plugs r gud (im preety sure), Coil and ignitor is good, disi is good, disi cap and rotor are good, fuel is at fuel rail but unsure how to check if its at each individual injector. Fuel is good fresh stuff.
Havent check compression yet but will do on the weekend.
So yea any ideas?
Engine is 2e telu.
starlet
Postby Adamal » Wed Jul 14, 2004 11:39 pm
You could try some injector cleaner. About $12 for a bottle (use 1/3 per tank of gas) from Repco.
Inaccurate spray could bugger things up terribly :(
Postby RedMist » Thu Jul 15, 2004 8:29 am
Have you checked the cam timing? Sounds like your a tooth or seven out.
Daniel.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby M R 2 Mk1 » Thu Jul 15, 2004 9:47 am
Yep timing definetly sounds like it, ands its so easy to set timing on a 4AGE you should be set :wink:
Working Sucks and Thinking is for Losers
M R 2 Mk1
Postby 10k 20v » Thu Jul 15, 2004 8:03 pm
IT AIN'T A 4AGE.
Are those engines air flow metered, perhaps you have a vacumm leak or if it is a/f then a hose off between the a/f and throttle body or failing that check your cam timing again
10k 20v
Users browsing this forum: Bing [Bot] and 4 guests
