how much power have you gotton from your gtz?
Postby B-style » Mon Jul 12, 2004 10:22 pm
just wondering, who has dyno'd there gtz out there and how much power did you make? from standard, pully'd, exhaust, etc..
cheers brent
1997 honda integra type r
1992 toyota levin gt-z turbo
B-style
Postby EVLGTZ » Tue Jul 13, 2004 12:44 pm
188kw @ wheels 8)
and more to come ...
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby 4ageturbs » Tue Jul 13, 2004 8:00 pm
Wow 188kw is a bit jade, hard core
4ageturbs
Postby NZ_AE86 » Thu Jul 15, 2004 8:41 am
That has to be with a Turbo?? 8O You can't make 300hp with the Toyota S/C!
NZ_AE86
Postby rollaholic » Thu Jul 15, 2004 6:26 pm
hehe the 4AGTE in his sig is a nice give away ;)
not to mention the lifetime of an SC12 on 18psi is about 3.5 seconds...
Postby aesc » Mon Jul 19, 2004 2:05 pm
Dynoed mine last week and got 120KW at the wheels on 9PSI, basically standard except exhaust from flexi and pod filter
EX AE101 owner
2013 Ford Focus ST
aesc
Postby EVLGTZ » Mon Jul 19, 2004 2:23 pm
aesc wrote:Dynoed mine last week and got 120KW at the wheels on 9PSI, basically standard except exhaust from flexi and pod filter
wow thats really good for a bog stocka. especially since they are suppose to be only 128kw flywheel power which is about 109kw @ wheels with only a 15% drivetrain loss :?
What type of dyno was that on? hub? rolling road??
EVLGTZ
EVLGTZ
Postby aesc » Mon Jul 19, 2004 2:37 pm
Yeah i was pretty happy with the result. There were 5 previous results by 1800 VTEC integras and mine was better than 4 of them and the top one only beat me by 4HP.
Umm, good question, not sure what type. Its the first time ive dynoed a car but the car was driven onto rollers (2 per wheel) set into the floor so does that help?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby EVLGTZ » Mon Jul 19, 2004 3:04 pm
ahh you say that beat you by 4hp, as opposed to your dyno reading you gave in killowats? You sure it was 120kw you meant and not HP??
EVLGTZ
EVLGTZ
Postby aesc » Mon Jul 19, 2004 3:08 pm
Yip beat it by 4HP, i got 158HP ATW but when converted it equates to 120KW.
EDIT: He beat me by 4hp i mean
EX AE101 owner
2013 Ford Focus ST
aesc
Postby EVLGTZ » Mon Jul 19, 2004 3:12 pm
well thats all good eh, most i've ever heard from a stock gtz 8O
EVLGTZ
EVLGTZ
Postby Andy from the block » Mon Jul 19, 2004 3:17 pm
aesc wrote:Yeah i was pretty happy with the result. There were 5 previous results by 1800 VTEC integras and mine was better than 4 of them
Thats awesome man. I was under the impression the 1800 vtecs made more power on dynos even though their on paper figure of 170hp is the same as the 4agze from what Ive read on Toyspeed and on NZhondas.
By any chance do u know if the vtec integras were autos?
Where did u get your dyno done?
Running 9psi boost? I thought standard was 8psi? Have u done the ABV mod aswell? What kind of intake and exhuast setup have you got?
Cheers.
Andy from the block
Postby aesc » Mon Jul 19, 2004 3:18 pm
Yeah unless its had cam work done in Japan, cos when graphed the power almost shows signs of tapering off at 5500rpm but then instead it kept increasing right through till 7000, where the 158hp was from.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby aesc » Mon Jul 19, 2004 3:29 pm
Cheers.
Yeah I thought the 1800 VTECs had more power at the wheels too, thing is those engines seem to respond really well to basic mods.
I dont know wheather any were autos, although i did recognise a few number plates (reg) from the list they had posted on their wall and they werent autos. There were 2 1600 VTEC Integras which I know are manuals and they only managed 122 and 127HP ATW. Got it done at Harman Motors here in CHCH.
Yeah 9PSI, think it was a 4th gear run so you seem to get higher boost in higher gears. Na havent done the ABV mod.
Intake ive only got a K&N pod, no cold air setup on at the mo. Exhaust is 2.5' from flexi with one 2.5' resonator and one 2.25' resonator, then twin 2.25' rear baffled mufflers
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Bazda » Mon Jul 19, 2004 7:18 pm
158hp=117kw :D
Postby aesc » Mon Jul 19, 2004 8:32 pm
haha my bad :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby VTEXTC » Mon Jul 19, 2004 9:51 pm
Is it me or do Rolling Road Dynos give lower KW readings?
I got 173fwHP (128.6fwkw)in the lude oin a hub dyno, slightly higher than two others.
The 20v Toyotas were struggling in the 90kw area(this IS NOT a bias figure either), a 1600 Teg got 114.6 fwkw i think, and another 110fwkw.
And a GTZ managed 116fwkw with the belt slipping at 7000rpm i think.
Hub gives higher (maybe less accurate ) readings? Or vice verca?
VTEXTC
Postby Bazda » Mon Jul 19, 2004 10:01 pm
hub should read higher, it does if u take it to Bob Homeward MotorSport
Postby RedMist » Mon Jul 19, 2004 10:05 pm
Similar issues, my NA 16 valve only ran 173hp at the wheels on a rolling road. Dissapointing. Cheap upgrade will be to run it on a hub dyno, at least another 5hp or so!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby VTEXTC » Mon Jul 19, 2004 10:31 pm
RedMist wrote:NA 16 valve only ran 173hp at the wheels on a rolling road. Dissapointing.
Ya What? 8O
VTEXTC
Users browsing this forum: Bing [Bot] and 26 guests
