Al wrote:Looks nice; but im still sceptical on the ct26. Get her on the car and dynoed
Wolf_Tm250 wrote:I'm going to mount the Caldina's intakre manifold & tb on my ST205,
but I saw that another difference is that the ST205's Throttle Position Sensor has 4 pins, and the new one only 3...
btw I think it should not be a problem to make it work with a Motec M4pro, right ?
fivebob wrote:4th pin is an idle switch, not required or used by the Motec.
Pirken wrote:Nice pictures of the cam sensor. This is and old tread but i wonder if any of you can answer me on this ?
Is the cam position either 475 or 115 degrees BTDC og somethin else ?
Im trying to get a AEM EMS to work on my caldina. but i cant get the crank to sync with the cam.
