regular maintainence
Postby dubious » Tue Jul 27, 2004 9:33 pm
hey
just going to do some work on my 4afe powered wagon
was going to do
plugs
oil change
air filter
any other things you advise to do?
just basic stuff
dubious
Postby playstation_12b » Tue Jul 27, 2004 9:36 pm
change oil filter while ur at it
playstation_12b
Postby Chickenman » Tue Jul 27, 2004 9:45 pm
Oil filter at the same time as oil?(I'm sure you are but just to be safe).
How old your beast? leads should be checked and possibly changed.
Do a search as well :D there's heaps of people on here who at one time or other have had the same questions. I would say search for maintenance but I don't think there are many here who can spell.
http://www.answerbag.com/c_view.php/870
May help you. it's got some real basic info (my kind of info :wink: ) about vehicles.
Baby Jesus
Chickenman
I Am The Walrus!
Postby VTEXTC » Tue Jul 27, 2004 9:47 pm
yeah depending on the age, you might want to change the fuel filter too :) could be slowing down with shit in it by now.
1998 Skyline R33 GTS25t
1:23.7/Manfield - Street Trim + Dunlop 03G
1:25.4/Manfield - Street Trim + Bridgestone Adrenaline
13.7 @ 105/MMP - Street Trim + Bridgestone Adrenaline
VTEXTC
Postby Rick » Tue Jul 27, 2004 9:55 pm
Gear box oil.
Postby Crimson Tears » Tue Jul 27, 2004 10:11 pm
Replace engine oil and filter, check and replace if required:
Air filter
Coolant
Brake fluid
Spark plugs
High tension leads
Fuel filter
Gearbox oil
When I first bought my car, I replaced every damn filter and oil, it's good to know where you are.
Cheers,
Mike
Crimson Tears
Postby rollaholic » Tue Jul 27, 2004 10:20 pm
ya one thing thats often neglected is brake fluid, topping it up is relatively pointless, but completely replacing it is a good idea particularly if you drive the car for long periods of time. you can get a special device which measures the water level in brake fluid (if you're getting the work done by a mechanic they may have one), but if you've had it for more than 12-18 months and never replaced it then its probably a good idea.
last thing you want is vapour lock ;)
Postby Ae92typeX » Wed Jul 28, 2004 1:52 am
rollaholic wrote:ya one thing thats often neglected is brake fluid, topping it up is relatively pointless, but completely replacing it is a good idea particularly if you drive the car for long periods of time. you can get a special device which measures the water level in brake fluid (if you're getting the work done by a mechanic they may have one), but if you've had it for more than 12-18 months and never replaced it then its probably a good idea.
Yea, I second that & the fuel filter for often forgoten service areas. For the brake fluid, just replace it if you dont know if its been done. One bottle is usually pleanty to fully change at all.
Ae92typeX
Postby kingcorolla » Thu Jul 29, 2004 11:51 pm
checking the brake pads/shoes couldnt hurt, jus so u know were u at, and how much stoppage u have left. U guys also missed out battery water level :wink:
1983 Carina AA63 4age
kingcorolla
Postby CAMB01 » Thu Jul 29, 2004 11:58 pm
Check ignition timing.
Replace Cambelt if it hasn't been already.
CAMB01
