i want an oil cooler
Postby mr20v » Wed Aug 04, 2004 1:13 pm
i run a silvertop in my aw11 and it gets a bit hot :cry: . i am after some info on engine oil coolers, price, availability, difficulty of attachment etc.
'84 20V AW11
'89 FX-GT w/ half-cage (MADFX - anyone want to buy a number plate?)
Click here for fancy porn!
mr20v
Postby Bazda » Wed Aug 04, 2004 1:18 pm
need an external oil filter adapter kit with steal braded lines, then an earls oil cooler where u tap into the braded lines. The thats about hmm $500+ later.
Postby Mr Revhead » Wed Aug 04, 2004 1:38 pm
or you could use the stock aw11 one....
Postby MR2boy » Wed Aug 04, 2004 2:05 pm
what stock all one, not all aw11s came with them
MR2boy
Postby MrBob » Wed Aug 04, 2004 2:55 pm
Bazda wrote:need an external oil filter adapter kit with steal braded lines, then an earls oil cooler where u tap into the braded lines. The thats about hmm $500+ later.
you can save alotta money by using pushlock fittings and rubber hose instead if the braided ones.. goto someone like enzed to sort these out
MrBob
Postby Mr Revhead » Wed Aug 04, 2004 4:08 pm
well its still an option!
on a different thread about oilcoolers some one (i think fivebob) recomended fitting a thermostat in with an oilcooler to ensure that your oil is only cooled when it needs it
Postby rxtoy » Wed Aug 04, 2004 5:37 pm
2nd hand oil coolers are $8 from pick a part, quite a lot of diesel cars and vans have them so they're not too hard to find.
i got one for my lancer a couple of weeks back for $17 including the lines and bolts to fit, i already had the adaptor kit though. might have a hard time finding one of them 2nd hand.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby FLAWLES » Wed Aug 04, 2004 5:56 pm
im planing to " try and and find " a evo oil cooler good flow propertys
i never thought of using a termostat our lamborghini tractors have a system simaler to this but it leads directly in to the sump via a termostat and a oil cooler the " about the size " size of a toaster i would like to use this on my ze but there a werid set up ie the air flows up instead of across and i cant figure out were to mount it
FLAWLES
Postby lvn_mr2 » Wed Aug 04, 2004 9:58 pm
Buy a stock aw11 one, it fits the 20v and they are pretty cheap. i brought the whole unit, filter adapter and hoses for $25 from a wrecker, and they came on EVERY auto aw11 and theres a heap of auto AW11's sitting in wreckers. if you want, contact Hillside wreckers in upper hutt, they have an auto with all the cooler bits still on it, they are also really well priced. your aw11 will already have the holes drilled in the firewall for the cooler, all you'll need to do is cut the water pipe and attach the cooler, and fit the filter sandwitch. OH one thing i forgot, you'll need an auto sump aswell as they have the drain drilled in them :D
done it before, really easy one day job and its not that hard.
just grab all the parts off an AW and you'll be sweet. no electricals needed here!
lvn_mr2
Postby Adamal » Wed Aug 04, 2004 10:12 pm
FLAWLES wrote:i never thought of using a termostat our lamborghini tractors have a system simaler to this
Hahahah got a Lamby tractor! Nice! :D
Amazing to think that they went from making one of the slowest things in the vehicle world to making some of the worlds fastest super cars!
Postby mr20v » Thu Aug 05, 2004 12:32 pm
being a mechanical engineer i dont see the point of heating up the engine coolant to cool the oil.
i guess i could just get a bigger radiator instead.
'84 20V AW11
mr20v
Postby rxtoy » Thu Aug 05, 2004 5:45 pm
cut the water pipe? do aw11's run water cooled oil coolers? or am i reading this wrong.
maybe try increasing air flow over your radiator with more venting or something along those lines? or a radiator with more cores, not that expensive to have done to your stock radiator and then it bolts straight into place.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby FLAWLES » Thu Aug 05, 2004 6:33 pm
haha yea trust me they r the only sex looking tractors in the world and the fastest to there govened speed of a wooping 40k in top gear 18th gear ha also change into 18th in reverse u can do 40k in rev as well also can get them wheel standing buy dumping the clutch and keep on changing up gears :twisted: :lol:
FLAWLES
Postby 85AW20v » Fri Aug 06, 2004 11:27 pm
I'd be looking at the reason for the thing getting hot. I've a 20v in my AW11 racecar and it never gets hot. Get the radiator cleaned out first and make sure that the coolant lines are hooked up the right way - it's back to front compared to the 16v i.e. the bottom line from the front goes to the thermostat housing below the distributor and the top one connects beside the exhaust maifold.
See ya
Simon
85 MR2 20v
85AW20v
