cracked headlight
cracked headlight
Postby Fred » Thu Aug 05, 2004 6:30 pm
hey does anyone know if you can still get a warrant with a cracked headlight? the crack isnt affecting the way the light is or anything still as bright as the other.
and also to what extent can u modify ur bonnet without needing a cert if u are allowed to modify it at all? like stiking a bonnet scoop on it is that alright?
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby Dr-X » Thu Aug 05, 2004 7:09 pm
you cant get a warrant with a damaged headlight. Even small, insignificant damage.
Dr-X
Postby Elmo » Thu Aug 05, 2004 7:20 pm
You CAN get a wof with a cracked headlamp, as long as it doesnt affect the beam, or allow moisture in.
We get cracked headlamps all the time at work, we put 'lite skins' on them, and they go straight through for a wof/cof
Generally, as long as there is no moisture in there, and its only a crack, ie it doesnt have the star effect on the back, then you wont have a problem.
Elmo
Postby GTUWET » Thu Aug 05, 2004 9:37 pm
mybonnet scoop is certed
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby MattrickMotorsport » Thu Aug 05, 2004 9:53 pm
Last edited by MattrickMotorsport on Thu Aug 05, 2004 10:10 pm, edited 2 times in total.
MattrickMotorsport
Re: cracked headlight
Postby Lloyd » Thu Aug 05, 2004 10:05 pm
Fred wrote:and also to what extent can u modify ur bonnet without needing a cert if u are allowed to modify it at all? like stiking a bonnet scoop on it is that alright?
Have a quick read of this:
http://www.ltsa.govt.nz/publications/vi ... ctions.pdf
My understanding of that is that as long as its not going to hurt someone or block your vision seriously then it shouldn't be too much of an issue. What scoop are you planning on? Best bet if you do put one on and aren't sure then dont try to get a warrent at VTNZ :) Find a nice little garage somewhere
Postby Fred » Fri Aug 06, 2004 12:11 am
bugger me then, got bout half a cup of moisture swiming in there. jst gna have to put the old lights back for the mo.
was jst curious bout any issues arising from stiking a small hole round air filter area, but was mainly interested in it cause mate wants to put a st205 gt4 bonnet scoop on his old shool gt4
Fred
Postby Elmo » Fri Aug 06, 2004 8:23 am
Take the light out and drain the water.
Elmo
Postby Lloyd » Fri Aug 06, 2004 8:37 am
Drill a little hole in the bottom to drain it, blow out the light with compressed air and sit the light in front of a heater for a while if the air doesn't get rid of all the water
Postby Fred » Fri Aug 06, 2004 12:03 pm
yea i could do that, but the light is cracked from end to end and im awaiting a replacement pair, so just easier to stick in the old ones for the time being.
o yea thanks hrt for that link. so as long as it kinda looks like its meant to be there u can do watever u want to ur car pretty much within reason
Fred
Postby Lloyd » Fri Aug 06, 2004 6:31 pm
Yeah, I'd be guessing so. Have a hunt through the LTSA site if there is anything you're not sure off. All the rules about warrents and the like are there in PDF format so you can have a look over them
