Celica Gt4 havin troubles!!!! valve lifters maybe???
Postby WALT3R » Sat Aug 07, 2004 2:23 pm
I have a 1990 gt4 3s-gte. It started makin a knocking noise between three and four grand, now all the time and even at idle. Thought maybe hydraulic valve lifters, ran a flush and oil additive and ran sweet for five mins then ten times as bad, the noise is coming right from the block..... any ideas, its a rythmic banging noise like someone hitting steel with a hammer
Why do babies shit themselves?.... sometimes you just dont know any better
WALT3R
Postby vvega » Sat Aug 07, 2004 3:27 pm
they dont have lifters
could be a bit of the tvis has gone into the combustion chamber
wouldnt be the first time
or perhaps naffed bigends
v
vvega
noise
Postby JasonZE » Sat Aug 07, 2004 4:01 pm
How does it sound on start up in the morning?
Sounds like you have crankshaft bearing problems :cry:
JasonZE
Real Life Mechanic
Postby RedMist » Sat Aug 07, 2004 6:13 pm
Naffed big ends.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby badidas » Sat Aug 07, 2004 6:51 pm
my moneys on big ends could be anything realy did you notice metal filings like a yellow copper colour in the oil that u drained ?
get your dipstick wipe the oil onto ur thumb and fore finger and rub them togather feel for nitty grittys in the oil
1989 mazda bongo aka [BNGBUS]
badidas
Postby fatgtr » Sat Aug 07, 2004 7:34 pm
yeah man my 3sge the big end bearings have gone. im just keeping my oil topped up so it wont get any worse. but in terms of yours getting ten times worse when u put that stuff through. should get it checked out
James
gotta love the punk music
fatgtr
Postby badidas » Sat Aug 07, 2004 8:17 pm
fatgtr wrote:yeah man my 3sge the big end bearings have gone. im just keeping my oil topped up so it wont get any worse. but in terms of yours getting ten times worse when u put that stuff through. should get it checked out
once the bearings are gone dude doesnt matter how much oil u putin it its still gunna seize probably when ur in the middle of nowhere or in the middle of an intersection knowing murphys law
badidas
Postby gtstarped » Sun Aug 08, 2004 11:27 am
[quote="badidas"] once the bearings are gone dude doesnt matter how much oil u putin it its still gunna seize probably when ur in the middle of nowhere or in the middle of an intersection knowing murphys law[/quote]
The big ends went on my MR2 GTS and because I knew what it was I didn't drive it at all. Due to this I just had the bearings changed and they have been fine ever since. The cars probably done another 15,000km since then.
Once a 3S-GTE starts rattling when cold I would recommend getting them done. Only cost me about $300 and thats far cheaper than $&#$% around with a new engine and a whole lot cheaper.
87 ST165 Prefacelift( RC Conversion)!!SOLD!!
92 ST185RC !!SOLD!!
01 Mitsubishi EVO7
gtstarped
Postby Malcolm » Sun Aug 08, 2004 1:13 pm
of course if you're not soft and don't mind getting your hands dirty and doing something yourself, big end bearings will cost about $60 for bearings and $10 for gasket sealant for the sump...
having said that it's most likely that it's already beyond repair, and you will need to pull the engine + gearbox out, get the crank ground and get new big ends and mains, which you would be looking at $250-450 if you can do the labour yourself.
Postby WALT3R » Sun Aug 08, 2004 2:50 pm
Thanks for the info guys.... just a little more. 1990 3sgte's have hydraulic valve lifters, so a squirt of oil sets the gap... I filtered the drained oil and found nothing at all in it (good sign), and the rattle is not part time, so when shes warm it still happens unfortunately... would anyone of you happen to know anybody in the rotorua area that could help me out? i must admit although im happy to do small work, the deep shit is over my head... cheers all.
WALT3R
Postby WALT3R » Sun Aug 08, 2004 2:56 pm
on start up in the morning shes the same, no change...oh and the chap that swore it has lifters is not so sure now haha, sorry.
WALT3R
Postby Malcolm » Sun Aug 08, 2004 7:40 pm
unless I am completely mistaken as to what hydraulic lifters are, 3sgte's do not have them, not in any version ever made
Postby Twolitre » Sun Aug 08, 2004 8:04 pm
All_Fours wrote:unless I am completely mistaken as to what hydraulic lifters are, 3sgte's do not have them, not in any version ever made
Yeah you're right man a lot of Nissans and Mitsi's use Hydraulic lash adjusters which have been known to create inconsistent valve clearances at high rpm which is why Nissan chose to use solid lifters in the GTi-R version of the SR20DET for motorsport purposes.
Any half decent engine reconditioner/builder should be able to do the work for you no worries.
Twolitre
Postby WALT3R » Sun Aug 08, 2004 9:17 pm
I had a chap come and have a look at it and he said that he thinks it could have them, it would make sense if it did, if the hole that the oil comes through to set the gap is blocked then it would make that noise, hence the flush, but since that did not work then we dont think it has hydraulic lifters. It doesnt really sound like big ends, but since a lot of people have pointed that way i will definately check it out... thanks a lot for all the advice. I will keep you all posted on the progress.
WALT3R
Postby Al » Sun Aug 08, 2004 9:33 pm
3s's dont have hydraulic lifters
heres a page from the toyota bgb for the 2nd gen 3sgte....no hydraulic lifters
Al
Postby WALT3R » Sun Aug 08, 2004 10:26 pm
Mate... you are a LEGEND... cheers
WALT3R
Postby Al » Sun Aug 08, 2004 10:31 pm
Anytime 8)
Al
