Knock Sensor 4AGZE AE101. WHERE IS IT LOCATED????? HELP!!!!
Postby Banga69 » Thu Aug 12, 2004 5:06 pm
Hiya just got my knock sensor and king toyota quoted me $200+ to fit it?
whats involved in this process? and is around $200+ the mark
clint
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby pplmvr » Thu Aug 12, 2004 5:16 pm
$200 hmm thats a bit steep etc..
The process involved including
1.Install the Knock sensor
2.Swipe your EFTPOS card for $200
3.Print you a receipts
4.Say thank you and wish you never come back for any warranty issues..
Big Is Good & Its Great to Play Together
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby Monsterbishi » Thu Aug 12, 2004 5:47 pm
pplmvr wrote:$200 hmm thats a bit steep etc..
Not all that easy really, have you ever looked to see where the thing is located??? Sure, $200 is on the steep side, but at least it gives you peace of mind that if they crack the block from over-tightening it(Knock sensor has tapered thread), it's up to them to fix it.
I'd assume that price also includes the new intake manifold gasket.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby pplmvr » Thu Aug 12, 2004 6:05 pm
I don't know speak to someone who really knows/cares like the owner of this car and if you know please tell us the processed involved ?! :roll:
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby Banga69 » Thu Aug 12, 2004 6:06 pm
hmm called back up any the guy said between $250-300 labout ONLY! 8O doesnt include the gasket. :roll:
any hookups that can do mine ???
hit me back $&#$% well over $300!! 8O
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby Monsterbishi » Thu Aug 12, 2004 6:26 pm
pplmvr wrote:I don't know speak to someone who really knows/cares like the owner of this car and if you know please tell us the processed involved ?! :roll:
Well, if you hadn't already guessed, the inlet manny has to come off, which means every vac line, etc attached to it, new sensor has to go in, with a thread locking compound, torqued up, and as already mentioned - being careful not to crack the block, and then re-assembly.
It's a simple job, just lengthy, and not without risk.
Oh, wait,I've basically just repeated my first post but in twice as many words, would you like step by step pictures, or are you taking a poly course in pointless criticism?
--- Cut Here ---
Monsterbishi
Postby pplmvr » Thu Aug 12, 2004 6:27 pm
No don't take it in the wrong way, I leard some stuff here today, thanks
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby fatgtr » Thu Aug 12, 2004 6:41 pm
what if hes paying by cheque. yeah it is a lenghty job but i would get it done properly coz u dont want a cracked block now do you?
James
gotta love the punk music
fatgtr
Postby Bazda » Thu Aug 12, 2004 9:52 pm
it takes me 15 minutes to change my knock sensor,
15 minutes $200..........wow!!
i'l do it for $150!!! :lol:
all u need is a 27mm socket thats deep reach.
then unclip th plug and pull it out, u might need someone to pull onthe wire while u push th elittle clip thing that holds it on.
then get the socket with an extension and go for it.
make sure u do it when eng is cold!! or u burn your self real bad :roll:
Postby Banga69 » Fri Aug 13, 2004 3:53 pm
Bazda wrote:it takes me 15 minutes to change my knock sensor,
is it really that simple? so how come king toyota quoted be between $250-$350 for 3-4 hour jobby?? are the ae101 and ae92 knock sensors in the same place?
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby spencer » Fri Aug 13, 2004 3:58 pm
yip they are in the same dam place
ms63 crown
spencer
Postby pplmvr » Fri Aug 13, 2004 4:15 pm
15 min
Gives us your insturctions here and we all save $$
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby Bazda » Fri Aug 13, 2004 6:43 pm
27mm socket thats semi deep reach, with the right size extension to bring it near the fire wall and still beable to get the rachet in.
next bit is tricky, u have to take the plug off the knock sensor by putting your hands down by the underside of the inlet manifold (very tight area) and push on the clip that holds it on,
then get someone to pull on the wire so it will then pop off, its hard to pull it off your self cos there is no space.
or u could use a screwdriver to push the tab down and then pull on the wire your self, this should slide out quite nicely.
then get your socket and put it on the knock sensor with the extension, and take it out.
putting it back on can be a pain, u can either try get it started with your fingers, or put the new knock sensor in the socket and put it on like this, why its hard using the socket is cos u cant align it straight with all shit in the way, so just have a play with it.
once its in push the plug back on.
I think toyota takes off the inlet manifold to make it easier thats where all the labour is.
so for this info that will be $40, u can deposit money into my account and send a cheque, either is fine.
bazz
Postby Al » Fri Aug 13, 2004 8:34 pm
Banga69 wrote:is it really that simple? so how come king toyota quoted be between $250-$350 for 3-4 hour jobby??
Dealership prices down here are around $75/h + gst. Do the math or find a cheaper mechanic.
Al
Postby Banga69 » Sat Aug 14, 2004 1:59 am
ok me and my mate had a look to find the damn thing but couldnt find it, once again i went back to king toyota and guy said its between the super charger and the manifold. and the only way to get to it is taking off the super charger. $60 hour+gst up to 3 hours
Bazda' how did it take you 15mins to changed it? ae92 and ae101 engines are different aint they??
help needed.
thanx
clint
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby Bazda » Sat Aug 14, 2004 9:02 pm
same eng bays.
check your pm
Postby rollaholic » Sun Aug 15, 2004 12:25 pm
i suspect the SC makes things a tad more difficult on the GZE?
Postby Bazda » Sun Aug 15, 2004 1:23 pm
none not really, the sc is on the drivers side, the knock sensor is on the passengers side of the block. it's basically the same to get both knock sensors out.
Postby Banga69 » Mon Aug 16, 2004 11:49 am
cheers dude, u have pm.
clint
CURRENT:
1994 Mazda Lantis
EX:
Banga69
