problems with big ends
Postby fatgtr » Mon Aug 16, 2004 3:40 pm
hey there
my big ends are going in my 3sge. its not extremly bad, but its there when it is cold. now i was speaking to a mech and he said that i will have to take the engine to a special engine shop to fix this problem. i dont know y this is, but i was wondering instead of taking it to shop why not replace the various engine parts, ie crank and rods?
what would you people suggest???
many thanks
James
gotta love the punk music
fatgtr
Postby Akane » Mon Aug 16, 2004 4:24 pm
Bearing shavings will be everywhere inside the engine, it's best if you just get a new 2nd hand engine.
Postby deaf_rattle » Mon Aug 16, 2004 5:54 pm
pull it out, full rebuild
Postby fatgtr » Mon Aug 16, 2004 6:04 pm
do you have an idea on the cost of that. like around 1 grand
James
fatgtr
Postby NZ_AE86 » Mon Aug 16, 2004 9:11 pm
If you pull it out, the rebuild should be less then a grand. :D
NZ_AE86
Postby Akane » Mon Aug 16, 2004 9:52 pm
fatgtr wrote:do you have an idea on the cost of that. like around 1 grand
Ofcourse I have, been there, done that, Twice.
Postby NA Drifter » Tue Aug 17, 2004 5:02 pm
i think, best bet is get another engine.. as i got a lemon 4age rebuilt engin that done around 5000 km. I only did about 600km driving and is sweet until i race the engine at Puke on sunday at D1NZ R4 and only lasted for 1 lap and a bit.. 2nd lap you can hear the bearing. :? so gutted
Keith
NA Drifter
Postby fatgtr » Tue Aug 17, 2004 10:33 pm
yeah its not that bad. it only happens when its cold. ill turn it on in a cold morning and it will knock quite bad but will stop. then when its cold i step on the gas and knock knock dies after about 3000rpm. then when it is warm it makes no more noise. kinda strange as when its cold i can push the clutch in and it stops, but take it off and it makes it, strange :?: :?
James
fatgtr
Postby jondee86 » Sun Aug 22, 2004 10:40 pm
Bearings knock because the clearances have become excessive due to accumulated wear. You can achieve the same result in a very short time by flogging the crap out of a new motor, or running without oil :)
Providing the bearings haven't seized (and yours haven't), you should be able to fix the problem by fitting new bearing shells. Usually this can be done without pulling the engine out, but I have never worked on a 3SGE, so maybe it's not possible on your car ?? Just drop the sump... leastways that is how I used to do it when I was careless enough to run big end bearings :(
Clean the bearing metal out of the sump while you have it off, change the filter and fill it up with fresh oil... you should be sweet !!!
Watch this space >>> <<<
jondee86
Postby Malcolm » Sun Aug 22, 2004 11:00 pm
i think the fact that it's only doing it when cold points to them just being quite worn, probably from not having regular oil changes, or possibly just from high km's. Big ends are pretty simple and cheap to change, just need to drop the sump off, remove oil pickup, remove conrod bearing caps and replace bearings, then put it back together and reseal the sump.
When it is an issue, however, tends to be when it's been run dry of oil when at full operating temp + high revs. This combination usually creates a somewhat more damaging result, with the bearings' coating disintegrating and flaking apart, usually scoring the crank and putting shavings through the engine. At this point you need to remove the crank and get it reground and get oversized bearings. This wont protect you if there are bearing shavings in the oil galleries, but it's a relatively cheap fix and should be reliable if done correctly.
Postby fatgtr » Mon Aug 23, 2004 7:35 pm
it also makes a sound when i go over a bump aswell. could it possibly be an engine mount. as it could go away when the heat expands the metal. just a thaught :?
although it does make sounds when i start it up on cold mornings
James
fatgtr
Postby pimpinmah0z » Wed Aug 25, 2004 5:19 pm
potatoe?
pimpinmah0z
Postby pimpinmah0z » Wed Aug 25, 2004 5:26 pm
i dont think its his big ends becos when the car warms up they go away, they dont get louder (the clunks) i figure its something that is kinda loose like an engine mount and when it heats up the metal expands and it goes away? any thoughts?
pimpinmah0z
NOISES
Postby CAMB01 » Wed Aug 25, 2004 10:02 pm
Sounds like Piston slap to me. Cold start the pistons are at there normal size, then expand as the temperature rises. 1 of 2 things or both: Worn piston skirts or worn bores.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
