also the rubber strip running along the top of the firewall at the back of the engine bay
Twolitre wrote:...also the rubber strip running along the top of the firewall at the back of the engine bay, this will alow lots of hot air to exit the engine bay...
Mr Revhead wrote:has anyone ever proven that works?
theres normally a rather high presure zone there, thats why gm had the cowl induction scoops on certain cars.... i take off the strip and them tape some strips of string there and see what they do... you may find air trying to get in there instead of out.....
Mr Revhead wrote:how the hell is that illegal??
Mr Revhead wrote:also the rubber strip running along the top of the firewall at the back of the engine bay
matt dunn wrote:The bottom of the windscreen is a high pressure zone in the air flow of the car as the air that flows over the front of the car has to cram into the same space as the air that flows over the roof.
This is why the factory collects air from there to go into the heater system.
If you have the air on fresh air not recirculate when you are driving at 100k you will get all that air coming through pushed by that high pressure.
Thats also why cars like tranzam race cars have bonnet scoops that collect air from the back not the front.
If you wedge the bonnet so it is higher at the back and has a gap it will
INCREASE OVERHEATING! So will removing the rubber strip in a similar way. Why else is it there?
Matt
mr30% wrote:thanks in advance, while on the move all is ok runs good, boosts good ,but if stoped engine bay heats up after that piss all boost This thing seems to hold so much heat that after 1 hour i cant put my hand on the intercooler.Any thougths on timed fan/hood scoop/hood vents/raised hood at rear/dont drive it in the summer/buy a honda : Im old and greyso please reply soon so I can get good boost befor I DIE
