Second how much effort is it to fit the quad throttles from a silver/black top to a blue top?
kingcorolla wrote:Second how much effort is it to fit the quad throttles from a silver/black top to a blue top?
I was thinking ov this also. If i keep the TVIS on, will i need an adapter plate to mount the quad throttles?
Plus does anyone know how 'cold start enrichment' is achieved on 4 throttle?
matt dunn wrote:20V's do nat have a cold start injector.
kingcorolla wrote:matt dunn wrote:20V's do nat have a cold start injector.
which brings me back to my previos question, how is cold start enrichment achieved on 20v 4 throttle? or is there none? but then it would run like sheeoot when its cold? and there is a thermo-time switch on the block which "should" activate cold start. Yes im a 20v virgin.
Stealer Of Souls wrote:Hey there...
I've got a couple of questions.
Firstly, can I bolt a redtop intake/throttle body straight onto a blue top without any hassles?
Thanks.
kingcorolla wrote:wen i think about it, u are rite, i would lose velocity creating an outward taper, even if adapter was as smooth as silk, but i have some querys...
i would be keeping the tvis unit, and this restriction would re-couperate for velocity loss throug the taper. (then why not leave factory intake?) because I THINK with the more free flowing 4throttles, rather than the one, aswell as maybe a bigger plenum with a high flow filter will MORE than recouperate for the loss in the small taper. Even wityh NO plenum, with individual fliters on the t/bodys would also create great flow.
what are your guys thoughts on this? i have not done this, this is simply what i think
