AE85/6 Dash
AE85/6 Dash
Postby coleman » Sat Aug 21, 2004 7:33 pm
ok i am pulling mine out of my 85 and putting into my panda.
anyone done this?
where is best to start??
will i end up with a big bucket of screws that i dont know where to put them?
coleman
Postby Xyrath 86 » Sat Aug 21, 2004 7:58 pm
I heard you have to take out the windscreen to get it out, not sure if its true but yeh.
Xyrath 86
Postby Shotgun » Sat Aug 21, 2004 8:03 pm
It's easier than it looks and of course you don't have to pull the windscreen out. Take all the lower parts off (glovebox and everything at that level) then work your way up. It's all screws and clips you have to fight against, fewer than you'd think. Once it's off look out for the steel crossmember that runs through it all because the back of it is freakin sharp. I sliced my hand pretty badly on it.
I was raised by a cup of coffee
Shotgun
Postby matt dunn » Sat Aug 21, 2004 8:40 pm
Shotgun wrote:It's easier than it looks .
Yes you do not need to take out the screen.
Will come out not to bad and you wont even have to remove the heater box etc.
Postby coleman » Sat Aug 21, 2004 8:45 pm
sweet, sounds like a saturday afternoon job in the sun next week,
cheers,
coleman
Postby spencer » Mon Aug 23, 2004 10:43 am
dude look out for the bolt behind the clock surround and the one behind the small vent on the passenger side can be a pain if you try pull it off with those still there. It is pretty straight forward pulled a few out recently
ms63 crown
spencer
Postby coleman » Mon Aug 23, 2004 10:45 am
cheers,
i pulled the lil surround around the clock out and it snapped, f*ck! very brittle plastic aye, do you have a spare one at all?
coleman
Postby spencer » Mon Aug 23, 2004 11:01 am
na sorry I broke my spare aswell gotta be carefull with them
ms63 crown
spencer
Postby coleman » Fri Aug 27, 2004 7:07 pm
ive got those 2 bolts in behind the clock and the vent on the left, i htink i got all others, but still not moving out.
do i need to pull off the part that surrounds the speedo first? or does that come with it?
coleman
Postby mike86ze » Fri Aug 27, 2004 7:59 pm
strip everthing that atached to it. glove/b, centre dash, speedo cluster and all its surround. theres a bar that runs behind the dash. most of it is bolted to tabs that come off this bar so follow the bar from one end to the other taking off all the bolts along the way. other hiden around too i think.
that clock surround is a prick.
anyone have a solution to nicely filling the gap left behind?
mike86ze
Postby coleman » Fri Aug 27, 2004 9:02 pm
the main problem is the speedo surround, i cant seem to get it of, looked for all the screws i can, but can seem to find any more, how much brut force should i put on it to pull it off? or am i missing something?
coleman
Postby matt dunn » Fri Aug 27, 2004 9:13 pm
TOYODA wrote:the main problem is the speedo surround, i cant seem to get it of, looked for all the screws i can, but can seem to find any more, how much brut force should i put on it to pull it off? or am i missing something?
Grab the wiper and headlight knobs and just pull them off.
Two large plastic nuts behind them.
Matt
Postby coleman » Sat Aug 28, 2004 11:18 am
Matt
thanks mate, i hope i dont brake them in the process!!
coleman
