Why did my speedo die?
Postby Stealer Of Souls » Wed Aug 25, 2004 3:51 pm
Hey there,
Well my speedo has just died... and only two weeks till WOF time...
So what could it be? The speedo is the only thing that has stopped working on the entire dash cluster...
My first thought was speedo cable... Is there anything else it could be? I have been mucking around with anything for months so it's unlikely I stuffed something up...
Help...
'86 AE85.5 Levin
Stealer Of Souls
Postby ~SlideWays~ » Wed Aug 25, 2004 4:00 pm
My digital speedo (standard) randomly reads zero every now and then, and then comes back completely inconsistently.
Its not the speedo cable connection to the gearbox cos i've checked that but i havent bothered to take the dash apart to check if its that end.
Only thing i can think of that mine could be would be the connection behind the speedo or some electrical fault/connection.
Do you have a normal mechanical gauge or digital? Because I may have the same problem as you :x
~SlideWays~
Postby AceSniper » Wed Aug 25, 2004 4:03 pm
prolly the cable
from there look at the speedo drive.....
gota mistory problem on a teg cables fine, replaced drive an still no go...
AceSniper
Postby kingcorolla » Wed Aug 25, 2004 8:04 pm
try this, take the instrument cluster out, run a wire from speedo input, to the other end of speedo drive cable (gearbox) and test for continuity with a multimeter. Keep going up the line, probing anywere along the cuircut were u can till u find the break.
that, or speedo drives fukd
1983 Carina AA63 4age
kingcorolla
Postby kingcorolla » Wed Aug 25, 2004 8:16 pm
kingcorolla
Postby hondapowergirl » Thu Aug 26, 2004 11:25 pm
AceSniper wrote:gota mistory problem on a teg cables fine, replaced drive an still no go...
Its my dash.... :roll:
it has to be
hondapowergirl
Postby Muzzie » Fri Aug 27, 2004 8:01 pm
~SlideWays~ wrote:My digital speedo (standard) randomly reads zero every now and then, and then comes back completely inconsistently.
Pull the dash and make sure the cable is attached to your speedo properly. The same thing happened on my Hiace, just after it would jump up and down 5k either way of actual speed, then it did what yours does then died completely - when it of course fell off the end. That's probably your problem.
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby Stealer Of Souls » Mon Aug 30, 2004 4:13 pm
Tee hee...
I'm silly...
After investigating the cost of building a custom dash cluster (something I wanna do at some point anyways) I decided to try and track the problem down...
Sure enough the speedo cable connection to the box wasn't done up properly and had come off...
Tee hee... i'm such a dork...
'86 AE85.5 Levin
Stealer Of Souls
Postby Muzzie » Mon Aug 30, 2004 6:00 pm
That you are my friend, although I don't like pointing it out publically :D At least it works though now :D
Muzzie
Regular Poster
