Blacktop 20v, anybody had probs with flat spots?
Postby NILPSI » Sat Aug 28, 2004 9:52 pm
As the title sudgests, my 20v seems to be very unhappy between 3000 and 4000 rpm most of the time, when its cold especially!!
When u get to around 3000 it starts coughing and splutering and backfiring really badly mostly when its cold, when it warms up you just get an extremely noticable hesitation!
Any help would be great as i feel like selling it, its pissing me off so badly
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby ~SlideWays~ » Sat Aug 28, 2004 11:13 pm
Have you done the usual stuff?
i.e. spark plugs, spark leads, air filter, fuel filter...
~SlideWays~
Postby RedMist » Sun Aug 29, 2004 12:32 am
Could also be a sensor. I'd be checking the ECU codes.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby CozmoNz » Sun Aug 29, 2004 1:13 am
mines absoutly gutless and jerky at low rpm + cold
i can balance the jerk from touching the throttle earlier during geardchanges, almost into burn the clutch tetorioty, but the revs dont jump or burn, and the car becomes very smooth, as it heats up and you rev higher, compensate by touching the throttle later.
this is what ive done, resulting in a very good drive, nice and smooth
apart form the bloody hard suspension and low profiles, hey look! a flyshit! *bang* $&#$% man, were flying :D
Rayne For President!
CozmoNz
Postby B1NZ » Sun Aug 29, 2004 2:03 pm
My AE111 sounds like a backfiring subaru driving down the hill on cold mornings until it warms up, I've changed plugs, leads, fuel filter etc etc.......
Once its warm its not a problem, i try and let the car warm up usually before i drive it and dont have a problem, its hard if your running late for work though!
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby NILPSI » Sun Aug 29, 2004 8:42 pm
Yea while its cold it does it, but unless its been running for mabee 30 minutes strait it still does it even when its warm, yes ive done plugs, fuel filter and its got a K&N pod on it (in custom airbox), i got my fault codes checked and it was showing up the rpm signal out of the dizzy, a mechanic friend cleared it but it still does it, ive heard from lith that i may need a new sensor in the dizzy as these are the same syptoms his bluetop had?? Have also been told to clean out my throttle position sensor.
Does anybody know where i can find one cheap :?
Im going to get it checked by an auto sparkie tomorrow, so ill get back to everybody about whats happening
Its also been doin this since ive had it, when i got it all it had was an HKS replacement panel filter
NILPSI
Postby sjt81 » Mon Aug 30, 2004 5:21 pm
Hi
Check out this post.
viewtopic.php?t=15965
My AE111 runs much better since I cleaned the throttle bodies. I used a Valvline product and just followed the instructions.
Hope this helps.
sjt81
Postby NILPSI » Tue Aug 31, 2004 9:57 pm
I went and had my fault codes re-checked today (after being cleared on friday) and now the ignition signal has come up, i was told that both the codes are caused by pick-ups in the dizzy
I have a 2nd hand dizzy coming and a local auto sparkie is gonna check it over before i get it fitted to make sure it doesnt have the same problem with the pick-ups, and then will be fitting it for about $30
Total cost is going to be roughly $250 so if it fixes the problem ill be happy :D
Will make a post thursday-ish and tell everybody how it turns out, fingers crossed :P
NILPSI
Postby RAZA » Wed Sep 01, 2004 10:04 am
interesting mine also has a bit of a flatspot at about 3grand when the engine is half warm.
doesn't seem to do it when its cold and the chokes on and doesn't do it once its warmed up but theres a few minutes in between where it stutters and sounds maybe like its dropping a cylinder.
Currently driving:
BMW 135i M
RAZA
Postby NILPSI » Sat Sep 04, 2004 12:18 am
Well doesnt seem that was the problem, stupid bloody cars!!!
Does anybody know where i can find a new engine :P
I hate my car sooo much right now, does anybody else have any ideas??
Might try cleaning the throttle position sensor and see what happens as that was also an option
NILPSI
Postby Boost_4_Life » Sat Sep 04, 2004 12:44 am
no good dude? I feel for you, electrics can be a bloody nightmare ( read f*in datsun still giving me woes too ). i'll keep my ear to the ground ;)
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby HZRDIZ » Sat Sep 04, 2004 6:06 pm
Yeh i cleaned out my throttle bodies today-bit of a mish thou just taking the cover off...
Car seems to be more responsive but not a hell of a lot... and the flat spot has sort of dissapeared...
Overall it has improved the drivability of my car...
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
Postby NILPSI » Sat Sep 04, 2004 10:38 pm
Well i bought some throttle body cleaner today should be doin it 2moro and taking the trumpets out at the same time, Also im taking it to toyota and get them to check it, i figure if they cant fix it then nobody can!!! Not to sure what else to check, have been told O2 sensor as well should be checked
NILPSI
Postby Deno » Sun Sep 05, 2004 6:02 pm
RAZA wrote:interesting mine also has a bit of a flatspot at about 3grand when the engine is half warm.
Mine is exactly the same, bang on 3 grand. Doesn't last long though.
You're just jealous the voices are talking to me!
85 MR2 NA faded red
86 MR2 Supercharged
90 Starlet GT (sold)
93 AE101 Levin parts car (PM if you need anything!)
97 Carib Sprinter (sold)
Deno
