oil leak quick fix
oil leak quick fix
Postby Voodoo » Mon Aug 30, 2004 9:36 pm
sounds dogey, but is there some sort of sealant that can be used to block leaks temperary, my oil pan seal is leaking abit and i need some sort of quick fix, as by the time i get car back from panel beaters i wont have much time before its entered into a show, and ive been told engine has to be lifted to get at it?
Voodoo
Postby z|gen » Mon Aug 30, 2004 10:02 pm
err..excuse my dumbness..but is the oil pan the same as the sump ?
cause if so..you dont need to lift the engine..just unbolt it from underneath and get some goop shiz..cant remember what it's called, but if you go to your toyota or repco..they might be tell you..and then just seal it that way..
but if the oil pan is not what i think it is..then disregard what i said up there..
AE91 SUPERCHARGED COROLLA
z|gen
Postby fangsport » Mon Aug 30, 2004 10:34 pm
or drain the oil out before the show so it dsn't end up on the floor!!!!!!LOL
fangsport
Postby Voodoo » Mon Aug 30, 2004 11:49 pm
haha, yeah sorry, i ment sump,
Voodoo
Postby evil_si » Tue Aug 31, 2004 7:27 pm
na sealant over a leak wont really work unless ur very lucky,
engine shouldnt have to cum out to do it, mind u what is it exactly?
id just drop the sump, clean it up and refit with new silicon
evil_si
Postby z|gen » Tue Aug 31, 2004 7:30 pm
heh..that was the word i was looking for to use before in my post, silicon..its a black goopy shit..and sticks to your fingers :x
z|gen
Postby Voodoo » Tue Aug 31, 2004 8:38 pm
engines a 4agze in a ae85, so is the sump just sealed with silicon? or is a seal and silicon used? a mech mate of mind recond it would need to be lifted up abit to get at it, but i havent had a decent look, at panel beaters at mo, so ill have a decent look when i get it back
Voodoo
Postby thaphatty » Tue Aug 31, 2004 8:42 pm
mate has one of them old boxy beemers and its $&#$% low, knocked a hole the sump, bogged it up 8O works well. good temporary fix untill you get it tig/mig welded back up.
thaphatty
Postby Spannergal » Tue Aug 31, 2004 8:59 pm
if its from the top of the sump then sealant will def help - david's right silicons the right stuff for the job :)
Spannergal
Postby Voodoo » Tue Aug 31, 2004 9:16 pm
yeah its just coming from the top of sump, where it seals, so just old plain silicon will do, like thew sh*t ya can get a mitre 10 etc?
Voodoo
Postby z|gen » Tue Aug 31, 2004 9:56 pm
im not sure if the stuff from mitre 10 will be best to use, but if its really cheap - might be worth a try, the stuff we use at toyota, as toyota written on it, and comes in a white squezze tube, Mr. Revhead might know the stuff im talking about if you ask him, unless you wanna wait till thursday, when i can check for you and get a price on it ?
z|gen
Postby Voodoo » Tue Aug 31, 2004 11:03 pm
cheers, ill give Warrick a try,
Voodoo
Postby badidas » Wed Sep 01, 2004 12:12 am
sump pans have a gaskit usualy carboard that will need replacing and put a small amount of silicon on each side of the new gaskit
1989 mazda bongo aka [BNGBUS]
badidas
Postby Spannergal » Wed Sep 01, 2004 9:26 am
a lot of idiots must have lot them at tech coz I never seen one :?
Spannergal
Postby kingcorolla » Wed Sep 01, 2004 4:44 pm
z|gen wrote: ...the stuff we use at toyota, as toyota written on it, and comes in a white squezze tube...
ye, its F.I.P.G (fit in place gasket)
and i thought most toyotas dont have sump gaskets? just silicone.
1983 Carina AA63 4age
kingcorolla
Postby z|gen » Wed Sep 01, 2004 5:07 pm
well, as far as i know, non of the toyotas i have worked on, and removed the sump on them have had a cardboard gasket and silicon, and even when replacing the sump gasket, iv never gone to see the parts boys for a sump gasket - always used silicon..it seems to do the trick..
z|gen
Postby levin_it_large » Wed Sep 01, 2004 6:02 pm
sorry to use ur thread but would silicone work on an exhaust leak or should i use a putty type compound?
levin_it_large
Postby z|gen » Wed Sep 01, 2004 6:47 pm
theres special exhaust cement which you can buy also..
depending on where the leak is..usually, youd replace the gasket, and put exhaust cement around it to seal..
z|gen
Postby Voodoo » Sat Sep 04, 2004 6:41 pm
ok i had alook at my spare 4agze and yeah , just a silicon is used to seal sump and a cover type thing for bottom of engine/top of sump? that a first i thought might be a seal , so anyway ill grab some silicon for repco , and give it a try if i get my car back in time for panel shop,
but before i drain oil and do this is there anything i need to be careful of, or any advice on doing this, as i dont want to end up with a bigger leak if it dosnt seal well
Voodoo
Postby kingcorolla » Sat Sep 04, 2004 6:59 pm
this is what id do..
-drain the oil
-whip the sump off
-scrape up the left over gasket on both sump and block
-clean both surfaces up real nice with a wire wheel on a drill
-Check for any dents in sump, or any reason to cause a leak
-apply generous amounts of silicone on sump surface
-whip the sump back on
-do the bolts up a little tighter if u feel the need!
should be mint after that 8)
kingcorolla
Users browsing this forum: No registered users and 45 guests
