Also what happens if the thing Shi#$ itself??
Thanks
Zomb wrote:Yea it sucks how they dont have a TPS(map sensor). I thinks its because the JDM ST165s dont have a factory boost gauge therefore dont have a TPS. So only 10psi can be used with the factory ECU.
vvega wrote:Zomb wrote:Yea it sucks how they dont have a TPS(map sensor). I thinks its because the JDM ST165s dont have a factory boost gauge therefore dont have a TPS. So only 10psi can be used with the factory ECU.
tps = throttle position sensor
and yes they do have a tps
they use the combanation of the afm and the air temp sensor in the plenum to work out airflow
and most will got to 12.5 psi without cut
there mapped to 12.5
they dont have a boost guage but they do have a boost light
v
Probably a code 34 which is overboost, did you hookup both wastegate hoses properly when putting the turbo back on the car?
Zomb wrote:so what could be my problem? ive changed the afm with a spare 165 afm and that didnt work. My oil gauge isnt working atm and the water temp gauge is only working sometimes. Could it be related to me only being able to run 10psi?
