st185rc 3sgte in a 93 mr2...
Postby triton » Thu Sep 02, 2004 8:57 am
is there any MAJOR modifications neeed to get the 185rc 3sgte in a 93 mr2 turbo chassis? and will the mr2 ECU be used or should i go with the 185rc ECU?
triton
Postby RunningRich » Thu Sep 02, 2004 9:27 am
You will need to use a number of parts off a SW20 doner engine. Refer to the info on this page and reverse it:
http://gtfour.supras.org.nz/3S-GTE%20Conversion.htm
That info is for the later version of the engine but you may find some of the info still applies.
You will need a MR2 ECU to run your power steering (not sure how people with aftermarket ECU do it?). You could set up a relay to run the RC IC pump.
Why do you want to use an RC engine?
Richard
RunningRich
Postby triton » Thu Sep 02, 2004 9:48 am
well i have an existing 3sgte out of an 93 mr2 turbo, just blew a ring land. i was also wondering if its possible to squeeze the a2w intercooler in the engine bay. the reason i chose it was b/c it was considerably cheaper (mainly because it was @ a local shop.
triton
Postby Twolitre » Thu Sep 02, 2004 5:45 pm
Why not just rebuild your engine? Always the oppurtunity to rebuild it with with stronger parts, ie. forged pistons or even st205 pistons.
If you want an RC water/air my friend is selling a complete water-air setup for $700 which is intercooler,radiator,pump etc
Twolitre
