GT-Four Won't Start!
Postby Audi » Thu Sep 02, 2004 11:30 am
I'm having some car troubles currently. I hoped out of my car to get some Subway and came back and it won't even try to turn over. The battery seems to be fine and I tried jumping it to no avail. It doesn't turn at all. I turn the key and nothing. I know thats kinda vague but any quick guesses as to what it might be and anything else I should try before I have to pay someone for help!
Dig a hole for the next man and you'll fall in.
Audi
Postby LowRydr » Thu Sep 02, 2004 11:38 am
starter?
///TRD Toyota Racing Development
take a really hardcore project idear, making it a reality? .....im 70% there
LowRydr
Postby Muzzie » Thu Sep 02, 2004 11:49 am
Tried clutching it??
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby Lanius » Thu Sep 02, 2004 11:56 am
I'm assuming you know the battery is ok coz your ignition lights come on ... ? Got a multimeter? Check as much of your electricals between battery / alternator / starter as you can ... just sounds like charge isn't getting to your starter motor (as LowRydr stated).
And yeh ^^^ Good point ... try roll-starting it.
Lanius
Postby celica_tommo » Thu Sep 02, 2004 12:04 pm
I occassionally have that problem with my 3s, it's most likely a poor connection to your starter solenoid or possibly my starting circuit i.e. alarm imobiliser connections may have come a bit lose. That's what I'll be checking when I get round to it
celica_tommo
Postby RunningRich » Thu Sep 02, 2004 12:53 pm
Pull the small wire off the starter and check what voltage it sees when the engine is being cranked. This gives an indication of the quality of the wiring leadng to the solenoid. There was so much voltage drop in mine that I had to put a relay between the battery and the starter and just use the starter wire to trigger the relay (there was enough current to do that thankfully).
87 GT-four BTW, shitty old crispy wiring.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Audi » Thu Sep 02, 2004 12:59 pm
Thanks I'll be checking those things out when I go back to it. Better start dammit! :(
Audi
Postby Audi » Thu Sep 02, 2004 4:46 pm
Weird. I went back to it and just tried it and it started first time. Mystery!
Audi
Postby Mr Revhead » Thu Sep 02, 2004 5:18 pm
starter contacts? if its done it once, and you fix nothing itll do it again!
Postby Twolitre » Thu Sep 02, 2004 5:36 pm
Mine would do that occasionaly when hot, more resistance in the wiring and/or starter
Twolitre
Postby Audi » Thu Sep 02, 2004 6:14 pm
I'll have a good look now its safely in the garage!
Audi
Postby levin_it_large » Thu Sep 02, 2004 6:26 pm
check the connections to your battery too, may be corroosive or just poor wiring not quite connecting, check your alternator too
levin_it_large
Postby vvega » Thu Sep 02, 2004 6:38 pm
lol
i had exactily the same problem
i just rol started it and then it was fine again
your solinid might be getting a little tired :D
v
vvega
Postby kingcorolla » Fri Sep 03, 2004 5:33 am
Mr Revhead wrote:starter contacts? if its done it once, and you fix nothing itll do it again!
if it was contacts he would here the the 'clink' of the plunger in the solenoid engaging.
if u have NOTHING at all, cept dash lights, could be a dodgy connection, or..... its your ignition switch contacts are dodgy/fukkd and the solenoid gettin no signal.
this was my prob in my te71, COROLLA of course :D
but that was 21 years old too btw
1983 Carina AA63 4age
kingcorolla
Postby vvega » Fri Sep 03, 2004 7:29 am
hehe
mine was a dry solder joint on the soilinod terminal
took a while to figgure that one out :D
v
vvega
Postby Mr Revhead » Fri Sep 03, 2004 12:16 pm
yeah thats true...
bloody electrics, have fun with it!
Postby tianporn » Fri Sep 03, 2004 5:02 pm
Do Toyota's have a fuel pump relay. It may need to get resoldered. Common as problem on Hondas
tianporn
Postby gtstarped » Fri Sep 03, 2004 8:24 pm
Yep its the same problem I have had and also ALLFOURS. Change the starter and be done with it. I had mine rebuilt at first and it still didn't fix it.
87 ST165 Prefacelift( RC Conversion)!!SOLD!!
92 ST185RC !!SOLD!!
01 Mitsubishi EVO7
gtstarped
Re: GT-Four Won't Start!
Postby kingcorolla » Sat Sep 04, 2004 5:00 am
tianporn wrote:Do Toyota's have a fuel pump relay. It may need to get resoldered. Common as problem on Hondas[
why dont you read his first post before u answer his question..?
Audi wrote:...it won't even try to turn over. The battery seems to be fine and I tried jumping it to no avail. It doesn't turn at all. I turn the key and nothing.
he turns the key and nothing. NOTHING! not a wind over with no fuel.
kingcorolla
Postby Audi » Mon Sep 06, 2004 11:33 am
Yeah sounds like it is my starter. Hopefully not a major thing.
Audi
