cambelt!
cambelt!
Postby semloshen » Thu Sep 02, 2004 2:15 pm
hi there
I have a 1991 ae92 4age redtop corolla.
Have just bought cambelt, 2xdrive belts, rocker cover gasket & seals.
now ive been told I need a "cambelt timing diagram" in order to change cambelt?
ive tried 'googling' it, searching forums etc but to no avail :cry:
would I find this info from a haines manual?
pls let me know!
Alex
Whenever I see an old lady slip and fall on a wet sidewalk, my first instinct is to laugh. But then I think, what if I was an ant, and she fell on me. Then it wouldn't seem quite so funny.
--Jack Handey Deep Thoughts
semloshen
Postby Mr Revhead » Thu Sep 02, 2004 2:24 pm
no you dont, just make sure you dont move ANYTHING whiel doing it
its a good idea to mark the cam pulleys before you take off the belt so you can align them ok.
if your really worried, just turn it over until the timing marks on the pulleys are at the top and inline with the marks on the backing plate
Postby ROBODISCO_20v » Thu Sep 02, 2004 8:16 pm
Dude if you havent done one before i'd take it to a mechanic to do. You can mess so much up if you dont know what you're doing.
But if you hell bent on doing it yourself then there are books you can get that tell you how to change them, hanes manual sould also help.
ROBODISCO_20v
Postby Monsterbishi » Thu Sep 02, 2004 8:21 pm
ROBODISCO_20v wrote:Dude if you havent done one before i'd take it to a mechanic to do. You can mess so much up if you dont know what you're doing.
His car is a AE92, so it's a non-interference 16v motor, worst he could do is spit fire out the inlet or exhaust :-)
If only all motors were non-interference, I'd be a happy man...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Lloyd » Thu Sep 02, 2004 8:44 pm
Get to the belt, turn the engine around until you see marks on the crank and cams that line up (should be reasonably obvious), take cambelt off, put new one on (tightly and without moving the marks away from each other), check marks are still right, reassemble and see if it still drives alright :)
Postby semloshen » Thu Sep 02, 2004 10:20 pm
ah great, cheers guys 8)
how much are these hanes manuals anyhoo? might be a good idea for me to get one, for any future work I may do.
:wink:
Alex
semloshen
Postby Monsterbishi » Thu Sep 02, 2004 10:29 pm
semloshen wrote:ah great, cheers guys 8)
:wink:
Alex
You should be able to pick one up for around $60, most public libraries have them too, so you can photocopy stuff, etc...
--- Cut Here ---
Monsterbishi
Postby fangsport » Thu Sep 02, 2004 11:22 pm
and if you have any reservations, get a white paint pen and dot the teeth on the belt. put a dot on the new belt and count teeth until you have all the timing marks. not so impotatant on a petrol motor but very handy when doing diesils as cam and injector timing IS critical, and both the cam and injector pump are sprung .
fangsport
Postby kingcorolla » Fri Sep 03, 2004 5:01 am
it always pays to replace the idler as well wen ure doin cambelts. Saves gettin up in there again when it starts humming :wink:
1983 Carina AA63 4age
kingcorolla
Postby Just_Juzz » Fri Sep 03, 2004 8:49 am
I got a haynes manual for my car for $59.99 + $2.00 P&P from hamilton.
But I know SUpercheap has a great range, as does Repco.
If all else fails try your local library.
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby Mr Revhead » Fri Sep 03, 2004 11:59 am
do haynes do one for the redtop? let me know if you find one, i know a few ppl who want one!
i can get some toyota ones but not the small port redtop
Postby 10k 20v » Sat Sep 04, 2004 8:33 pm
a 16valve 4age is a 16v 4age. All the timing marks are the same.
10k 20v
