Bazda wrote:heavier flywheel woudl make it easier to launch, lighter one would make it alot more difficult.
edit:
yes you are correct.
Dr-X wrote:Mr Revhead wrote:or you could play with other aspects of the engine, such as intake design injector placement etc etc
but i think the point you are trying to make is changing the flywheel to alter the torque wont work, which is correct
Read my post again, but pay attention this time.4AGTE wrote:If i have a lightend fly wheel this will kill bottom end will it not and help it in the high end rev's?
Torque and hp are directly linked and you canot change one with out the other being different right?
But you can change your tourqe/hp down low with cam gears/ fuel ratios.
Is this not right?
Correct, I'm just trying to bash out of peoples heads the idea of sacrificing power for torque at any particular rev range without changing drive ratios.
The point I'm trying to make is that statements such as "I'm trying to do this to increase my bottom end torque" are fundamentally impossible, unless you're talking about going to a different diff ratio.
as power and torqe are directly link you cannot increse one withou the other in a givn rpm
Mr Revhead wrote:the point i was trying to make is it is possible to change torque or horsepower with out affecting the other, or affecting it much.
Taking weight out of a flywheel doesn't make any difference to power, but it does reduce the inertia. This means less torque is absorbed in accelerating the flywheel, making more torque available for accelerating your vehicle. This will only be felt in the low gears, where the rate of change in engine speed is greatest .
A modest reduction in weight (at the outside rim for best effect) will not affect the driveability of your car.
jondee86 wrote:Some guy wrote this a couple of weeks back...Taking weight out of a flywheel doesn't make any difference to power, but it does reduce the inertia. This means less torque is absorbed in accelerating the flywheel, making more torque available for accelerating your vehicle. This will only be felt in the low gears, where the rate of change in engine speed is greatest .
To make the point quite clear.... changing the weight/inertia of the flywheel does not change the amount of torque the engine produces. But for those few seconds when the engine is accelerating RAPIDLY, there will be more torque available at the wheels.
Cheers.....
jondee86
Dr-X wrote:jondee86 wrote:Some guy wrote this a couple of weeks back...Taking weight out of a flywheel doesn't make any difference to power, but it does reduce the inertia. This means less torque is absorbed in accelerating the flywheel, making more torque available for accelerating your vehicle. This will only be felt in the low gears, where the rate of change in engine speed is greatest .
Cheers.....
jondee86
Yeah, more magical torque came from the mysterious 'power land'. Goody, why bother with anything else when we have free magical torque at our wheels!
kingcorolla wrote:the question im wondering, is does more weight in rotating parts absorb torque?
kingcorolla wrote:the question im wondering, is does more weight in rotating parts absorb torque? or the engines ability to rotate?
kingcorolla wrote:remembering in point is that the reson for this thread is that 4AGTE wanted to DECREASE torque in low-mid range, to stop exsessive wheelspin remember? or at least shift his max power/torque figures. maybe we should be arguing about that, rather than every theory under the sun about rotating mass vs torque??
4AGTE wrote:Basically if I put on a lightened fly wheel it will move my torque curve at the wheels and possible help and push maximum torque up the power curve a little at the WHEELS their for possible being able to get more power to the track their for better quarter mile times.
Users browsing this forum: Bing [Bot] and 28 guests
